The difference between Natural Gas Set Up and Propane Gas Set Up on Fryers are as follows: Natural gas burner orifice has larger bore (#52) than Propane Gas burner orifice (#55 or #56). Gas Valve's spring kit for natural gas has less tension (thinner) than Propane. You have to order burner orifice ( the quantity depends on the number of burners your fryer has), pilot orifice and Gas Valve Spring Kit for Propane Gas if your fryer is set for Natural Gas or vice versa.
You must first check to see if your pilot flame is good. If it is too weak, or not impinging properly on the thermopile, it will not stay lit. If the pilot flame is ok, the problem could be that the thermopile is weak. using a millivolt meter, test the voltage across the thermopile while the pilot is lit (you may need someone to hold the button down while you do this). You will also need to disconnect the thermopile's leads from the control while you do this. You should get about 750 millivolts across the thermopile while the flame is on it (let it heat for a while to stabilize). If your reading is too low, your thermopile may be shot and needs to be replaced. That is of course only if your flame is proper. That voltage is needed (or close) to keep the magnet open so it will stay lit when you let the button go.
