Copystar cs6030 machine have a error code (C7210)
2 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: Copystar/Kyocera 1620 error code: C-6 000
The fuser needs to be reset.
Posted on Mar 04, 2009
Error code copystar cs 6030 c4120
Fuser etror check for paper jams in fuset snd remove as nd tufn off and on to reset,or rdplsce fuser assu.
Dec 14, 2015 | Copystar CS6030 1-TK659 Standard Black...
Copystar cs6030,all thing are ok but not printing. the paper come out white.
you need to run the simulation 130 in order to add toner to the developer, after that you will be good.
Nov 12, 2015 | Copystar Office Equipment & Supplies
Copystar C2300 problem ?
fuser motor lock. bad fuser or exit turnover assembly not rotating properly. the duplex unit could also bind causing this. run u030 in service mode to check the motor.
Dec 11, 2014 | Copystar Office Equipment & Supplies
Copystar s 2085 error code c5
A complete list of Copystar error codes is here:
Copystar Error Codes
Nov 03, 2013 | Copystar Office Equipment & Supplies
I have a brand new Copystar CS-3060 turn it on and a ERROR CODE 3100 appears on the screen what does this code mean please??????
The scanner is locked...look for some large yellow screws on the side of the machine or on the rear of the machine inside of a detent. Turn it left until it pops out to release the scanner.
Mar 11, 2010 | Kyocera CopyStar CS-3060 Black and White...
Copystar 2221, C30 code
Hello sir; I believe your error code should be C030, if that's correct that 's mean main board is bad , it not worthy to repaire it, go buy a new machine.
Mar 06, 2009 | Copystar Office Equipment & Supplies
C 610 Error Code on a CS-1505 copier
There is no 610 code ,there is 620&630 which are fuser problems.press and hold down these keys,stop/reset key /start key/copy density key.Press stop/reset keyb again. enter U163,press start."CLE"will display.Press start again to clear.Exit the mode with 001.
Dec 04, 2008 | Copystar CS-1505 Copier
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Copystar 2014 UF error code need help
Take Out Toner Cartridge. Looking straight through there should be a tiny switch that tells the machine there is a toner cartridge present. It might have just gotten out of position or may be broken, which means you'll have to replace it!
Aug 19, 2008 | Office Equipment & Supplies
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
29 people viewed this question
jasbo
jasbo
