Question about Canon imageRUNNER 3030 Black and White Copier
Canon ir 3030 printout will be black
More details mean experts have more info can given a better answer and solution.
    New Friend:
  • 45 Answers
Verify charge corona, when you start a new copy, open lateral door when paper is in the right of drum, then look if the drum is full covered with toner.
Posted on Dec 06, 2014
Testimonial: "no, drum unit is working. but printout will be come black color. white paper comes black letter or not print. its come black color printout."
  • Iulian_d Dec 06, 2014
    Ok, but if you open lateral door when you print, you can see image on drum?
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
How to change Laser In canon ir 3245 When printout it totaly black.
Hi. I think that the laser unit doesn't cause that problem . First check the drum unit maybe there is dirt In the contact points
May 24, 2017 | Canon Office Equipment & Supplies
SYSTEM ERROR E007 ON CANON iR2018
Call to 1-800-243-0019 Canon ir 2018 system error e007 code means that the fusing film is out of Home Position or the film is ripped. You will need to most likely have the fixing film.
Apr 15, 2017 | Canon Office Equipment & Supplies
IR 3035 black copy
<Cause>
On some types of paper (especially those with a high calcium carbonate content), toner offset to the fixing film can
start to cake, moving from the fixing film or the pressure roller to the face or back of paper.
<Field Remedy>
Use the following service mode item to change the timing at which the fixing pressure roller is cleaned:
COPIER>OPTION>BODY>FIX-CLN
0: disable cleaning (default)
1: execute cleaning during last rotation every 500 printouts
2: execute cleaning during last rotation every 200 printouts
3: execute cleaning during last rotation every 100 printouts
Feb 14, 2017 | Canon imageRUNNER 3035 Black and White...
Canon ir 3030 paper loading problem in cassette
The problem could be one of several things.
1) Check your "printer preferences" setting and make sure you have selected the CORRECT SIZE OF PAPER. For example; Letter, Legal, etc.
2) Un-install and re-install the drivers.
Hope these suggestions help.
Nov 03, 2014 | Canon imageRUNNER 3030 Black and White...
IR 3030 error code E000020-0000. I am looking to find out the what this error code means. Thanks in Advance
Hello Cg
Well, the code means that the path between the toner bottle and the toner hopper is clogged. In 5 years of dealing with this device I have never seen that to be the case and our company has a pretty big poulation.I also have been working on copiers for 23 years. I can only guess, but have you recently had a new drum put in due to poor copy quality? If so, the installer may have disconnected the connector to the developer unit. We need to turn the main power off (located on the right side.....rear like a light switch) and TRULY power off the copier. Then verify the connector to the developer unit in seated properly. Then power the copier back up. If this does not help then you have have a unique and ugly problem that may require a tech. I hope not, thats why I'm trying to help. Good luck. SPINAL
May 04, 2011 | Canon imageRUNNER 3030 Black and White...
I have a canon IR 2870 Photocopier it detected error E000000-001
there is something wrong with your copier's fixing unit.FIxing unit is located on upper side of drum unit.you can see when you open copier left door.a caution about heat is displayed there.the main reason of this error is your fixing unit heater not working or its heat is not detected by thermisters.
check all connection , check heater status,check thermister contact or wiring .replace heater or replace fixing unit.
Jan 19, 2011 | Canon imageRUNNER 3030 Black and White...
Bottom half portion of the paper horizontally gets black (dark)
I would presume that somwheare beneath adf is light coming to scanner. Try to adjust height and possition of adf on adf hinges.You have two screws, one for height, and other for left or right possition.
May 25, 2010 | Canon imageRUNNER 5000 Copier
Canon IR 3030 error code 000 002-0000
This code is for the fixing area. I have found that most times it is the lower pressure roller bearings that have seized up and need to be replaced. it could also be the main thermistor has a problem, it would have to be replaced or cleaned ( try cleaning first). on the rare occasion a retaining clip has broken and had jammed the upper roller. The best thing would be to check everything in the fixing area. it is under the yellow cover that gets very hot.
Feb 23, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER 3030 Black and White Copier Logo
76 people viewed this question
old marine
old marine
