Question about Kenmore 800 6983 Electric Dryer
The dryer will only run when put in the 70 minute position
Nothing yet
The timer mechanics inside has a problem with the switching
and it needs a new timer clocked control
look too ebay for one cheep
Posted on Dec 05, 2014
Dryer will heat when put on 70 minute cycle but will not heat total time. if you put it on 20 minute cycle will not heat at all.
Hi, Some dryers have a cooling cycle that lasts for 20 minutes to cool the drum and its contents so you don't burn yourself when getting clothes out.
alot of machine have a max drying time of 120 minutes 20 of that will be for cooling so 100 mins hot!
the cooling cycle is usually indicated near the end of the dial in a different colour to that of the hot cycle.
Hope this helps.
Feb 11, 2011 | Dryers
Dryer was running I opened the door took clothes out shut the door but not all the way just till it was in the full up position. Then went back later and put some clothes in and hit the start button and...
i had this same problem it sounds like a thermal fuse its usualy a small device white mabe with 2 wires connected to it on the back of your dryer there might be a cover plate but you shouldn't have to tear into your dryer, you can also check em with an Ohms tester,to see if the thermal fuse is working properly
Jan 03, 2011 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
My Kenmore series 70 dryer heats up but takes 3 times on 70 minutes to dry the clothes. After every 70 minute period when i check the clothes i open the dryer and it is like a steam room. It is getting...
Check your dryer venting for obstruction.  Take the vent hose off and run the machine,  If it works with the venting disconnected, It is between your wall and the outside of the house.  If it still has the same problem it is somewhere in the exhaust.  If the dryer can't circulate air, nothing will dry.
Dec 04, 2009 | Dishwashers
70 series dryer was workin put in clothes started and it quit,turn timer to any position no ticking no nothing,any ideas?
Check thremal fuse on the exhaust duct.  It is a safety which blows when your exhaust temp reaches 250 degrees.  It is the one with 2 blue wires going to it and is located on the exhaust duct.  If it is blown you will also need to replace the operating thermostat which is right next to the thremal fuse.  Then check your dryer venting for obstruction as this is often the reason the fuse blows in the first place.  Also make sure that power is getting to your dryer.  You might have blown a breaker.
Oct 25, 2009 | Kenmore 73952 Gas Dryer
Gas dryer heat is intermediate
does the igniter glow white or orange? if it is orange you need to replace it. has to be white hot to ignite. if the igniter is white it could be the coils not opening the gas valve all the time - an intermittent problem.
Oct 04, 2009 | Kenmore 73952 Gas Dryer
I have a Kenmore 70 series dryer. It will run for
check if the negative is connected on the back of the dryer ,make sure its tight,if not then the heater coil will need to be changed for sure.if my info was of any help to you then please leave a comment ,thankyou.
Sep 02, 2009 | Dryers
Kenmore 70 series dryer problem
HI. This may be an issue concerning the pressure switch that is located inside the rim of the actual door.
This switch activates the main drum motor when a cycle is selected when you are ready to dry your clothes. As soon as you select the desired cycle and you load the clothes and shut the door, the last thing to do is push the start switch. if the door pressure switch is malfunctioning, it will not allow you to start the dryer. it will simply not spin.
If you can visibly see the light inside the drum/basket while the door is closed, this will confirm the malfunctioning pressure switch that is located inside the inner part of the door rim.
Its located in this position so that the actual door can make contact with it, in return, applying pressure to close the switch and complete the circuit. this will cause the dryer to spin.
You stated that you can see the drum light shinning when the door is closed and, this will confirm my diagnosis. You can preform a hard reset just to make sure of this defect. Simply unplug this unit for 5 minutes or, shut down the circuit breaker for 5 minutes as well. Any methods will work. Once the 5 minutes are up, simply plug back in this unit and try to run a normal cycle. if this problem is still and issue, it will once again confirm a door pressure switch failure and you will need to replace the switch in this unit.
I would check the wire clips and connectors as well located on this switch for lose or worn contacts. this can be a problem spot as well.
Please rate and god bless:)
Apr 26, 2009 | Kenmore Dryers
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Kenmore 70 series clothes dryer
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
Feb 15, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 800 6983 Electric Dryer Logo
56 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
