Question about Pool & Spa
I have a manual Herman pellet stove. The auger gets jammed often. Should i have the pellet box filled? Would this make a difference? Thank You.
    Champion:
  • 219 Answers
If you have the pellet box too full this will cause the auger to jam.
Posted on Dec 05, 2014
  • patty Dec 05, 2014
    Thanks, Jerem. Actually the box was pretty low.We r taling about the big storage box top, correct? Its just that it lasted through the night but then stopped filling this A.M.
    sorry the spellngs..the typing is weird on this site
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
Traeger pellet stove minuteman MPW070 user manual
does the auger in my mpd070 pellet stove have a carrier on both ends
Feb 08, 2014 | Kitchen Ranges
Jamming auger onmagnum countrysidepelletstove
The softwood pellets are not the problem. The problem is the quality of those pellets. Make sure you are not using last years fuel and it has not been stored outside. Also check the auger system for junk, gouging and bending of the auger.
Nov 26, 2013 | MagnuM Countryside Pedestal Corn Stove
My auger on my napoleon pellett stove got noisy and then quit working. Is there a reset button and how do I find it and get it to work? I already gave my credit card information and was not able to chat...
Did i sound as if the auger got jammed when you first heard this noise? Or was the stove overheating? Have you changed the brand of pellets recently, from what you had been using? These are just a few of the things that can cause a pellet stove auger to stop working.
Yes, there is a reset switch, but since you didn't mention which model Napoleon Pellet Stove you have, it's hard to know where to tell you it is.
However, most Napoleon stoves are very similar in how they work and their mechanics. So, I have included a link to an Owners Manual for the NP140 Model. This should point out the things I mentioned, as well as other causes and how to solve them. Be sure to check out the Trouble Shooting Guide.
http://www.napoleonfireplaces.com/Tech/installation_manuals/NPS40_NPI40.pdf
You can download and print this manual if you like.
If you weren't able to chat with someone about this, you want be charged the Chat rate.
Hope this helps head you in the right direction.
Feb 26, 2011 | Heating & Cooling
The auger is not turning to fill the burn pot with pellets. Can hear the motor run but it will not turn it.
Have you recently changed the brand of pellets form what you have used in the past? If so, please understand that no two wood pellet manufacturers make their pellets the same way. If this is the case, you will have to retweak your stove to that brand of pellets you're now using. Also, check the auger to make sure it's not jammed and that auger shaft is properly fitted into the auger drive motor coupling..
Hope this helps solve your problem.
Feb 15, 2011 | Heating & Cooling
Cozy model 100 pellet stove.auger seems to be jamming sometimes ,removed motor and it turns,could problem be in gearbox?have motor in a vise and it has been turning for 4 hours
How about the pellets getting trapped between the auger and case? Look to see that the auger is down and seated correctly, not saying that the gear box is not the problem. I just think that you should look at all of the simple things first. Does the auger spin freely with out pellets in it? How are the bearings on the auger? Does it require lubercation? Does the gear box turn easily with out the motor?
Dec 23, 2010 | Cozy (W352E) Heater
Pellet stove augur starts and will start burning and then it back up pellets will not come out the augur will not spit out the pellets and they just get chared
auger may be jamming or motor is starting to go unplug unit and open back and oil auger motor and check operation- auger may not be sitting right in feeder tube also try a different pellet some pellets are bigger(sizes vary from company to company) which sometimes jam at feeder in hopper
Nov 26, 2009 | Ruud UBHC Air Conditioner
Purchased a used Earth stove mp240 pellet stove and the auger does not move. we are looking for a manual or information on this stove it is an older stove we just don't know how old. Thank You
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Jun 10, 2009 | Napoleon Auburn Pellet Stove Heater
AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
Jan 16, 2009 | Napoleon Auburn Pellet Stove Heater
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Pool & Spa Logo
148 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
