Question about Cycling
Will this fit past the spare tire on a Jeep Wrangler to reach the hitch?
It is pictured on a Jeep Cherokee which has the spare underneath, but looks to be back a ways from the tailgate. I'm hoping this will fit my Wrangler without modifications. here is a link. http://www.gearbuyer.com/products/swiss_cargo-lugano_hitch_mount_4_bike_rack.html
I found the lug wrench and jack. Where is the nut to lower the spare and where is the 4-sided adapter stored?
How To Lower Your Spare Tire - YouTube
? 1:27
https://www.youtube.com/watch?v=6rLi0I7vRIw
Mar 30, 2011 - Uploaded by Garden City Jeep Chrysler Dodge Ram SRT
The staff at Garden City Jeep Chrysler Dodge are ready to help you. ... Garden City Jeep Chrysler Dodge has The Can-Do Crew show you how to lower your spare tire. ... Pacifica, Durango, Charger and Liberty for the Hempstead, Queens, Brooklyn ...Installation of a Trailer Hitch on a 2006 Chrysler Pacifica ...Missing: nut ‎sided ‎adapter ‎stored
Fix a Flat Tire: Chrysler Pacifica - CarCareKiosk
www.carcarekiosk.com/...Chrysler_Pacifica...3.../change_a_flat_tire
Free video on how to fix a flat tire in a 2005 Chrysler Pacifica Touring 3.5L V6. Complete instructions for using the jack kit and spare tire in a 2005 Chrysler Pacifica... Most Chrysler jack kits include the jack, a jack handle and a lug nut wrench.
Jan 05, 2016 | 2006 Chrysler Pacifica
How to store spare tire
Is it mounted on the back carrier or underneath the car?
If underneath, open your rear door, on the rear surface where the door locking mechanism is, check for a bolt that can be turned left/right in order to lower the spare tire locking chain.
Jul 13, 2012 | 2000 Jeep Cherokee
No owners manual. How do I get to the spare tire? Can't tell if I'm supposed to go through the floor in the back or under the car.
The spare tire in a 1996 Grand Cherokee is supposed to be bolted on the inside the rear trunk area, on the drivers side, not underneath the Jeep as you think. The only thing under there taking up all the space is the gas tank. If it's not in the back, then you don't have one. The jack and tire iron are located under the rear seats.
May 04, 2011 | 1996 Jeep Grand Cherokee
Spare tire tools
From the owner's manual for that model, see link below also, page 299 of the PDF has a nice picture.
Spare Tire Removal
Fit the jack handle extension over the drive nut. Use the
Lug Wrench to rotate the nut counter clockwise until the
spare is on the ground with enough slack in the cable to
allow to pull the tire out from under the vehicle.
CAUTION!
The winch mechanism is designed for use with the
jack extension tube only. Use of an air wrench or
other power tools is not recommended and can
damage the winch.
When the spare is clear, tilt the retainer at the end of the
cable and pull it through the center of the wheel.
http://www.jeep.com/en/owners/manuals/index.html?year=2006&nameplate=Grand%20Cherokee
Oct 04, 2009 | 2005 Jeep Grand Cherokee
Spare tire mount on 1986 Sieraa Classic
I had a similar problem with an 88 F250. Measure the tire height with tire standing, then measure space between hitch and measure frame from same place.
If the space between the frame would allow the tire to fit without the hitch, you need a wider hitch. If your current hitch has room for the tire you are all set.
Usually a heavier class hitch will have wider mounting points, but be aware that access to put in bolts may require you to weld the hitch to the truck.
Jul 17, 2009 | 1989 GMC Sierra
1998 Jeep cherokee Marker (left side only) lights not working
on 97 and later modles there is a fuse panel located behind a small access panel in the right cowl trim panel
Jul 16, 2009 | 1998 Jeep Wrangler
Jeep wrangler change tires..
Changing tires on a 2007 Jeep Wrangler is no different than a typical vehicle. Any local service facility can help out.
If you are wanting to do it yourself:
1. Break the torque on the lug nuts while the vehicle is still on the ground. 2. Jack up the axle using the jack in the trunk (under the panel in the trunk floor) 3. Remove the wheel and tire 4. Replace with the spare or a new tire 5. Tighten the lug nuts to 85-90 ft-lb of torque, make sure you tighten in a star pattern.
Jan 25, 2009 | 2007 Jeep Liberty Sport
2003 Wrangler Tire buying dilemma.
1) If you want performance in the rain, you need an all season tire.
2) I had 31x10.5 on my Jeep.
3) The vibration could be a bad steering damper.
4) Dana rears are almost ablong shaped on the cover. The other is perfect round shape cover.
5) Tell your wife the Jeep is for her.
Nov 18, 2008 | 2003 Jeep Wrangler
Throttle cable???
Have a look at the cable where it hooks up to the throttle body.
Have someone push down on the accelarator while you look, make sure the throttle body is opening all the way.
Jul 11, 2008 | 2001 Jeep Wrangler
Cycling Logo
71 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
