Question about Monster Iclarityhd Bluetooth Speaker System - Clarityhd Clarity Iclarity Hd
How do I get it to recognize more than one device
It works with my Iphone but I cant get it to connect with my ipad mini
How do I use udrive mini with my IPhone?? I downloaded the app and put drive in my phone but wanted to down load my photos and videos to it but not sure how to do??
here is your info
Search Results
uDrive - Lightning Flash Drive with USB Connector for iPhone and iPad
https://www.gmyle.com/products/udriveiflashotg Rating: 3.1 - ‎28 reviews
Mini flash drive instantly free up memory up to 128GB on iPhone. Easy backup ... Disappointed about the new lightning side mount, is too wide for my otter box.
U-Drive on the App Store - iTunes - Apple
https://itunes.apple.com/ca/app/u-drive/id934692938?mt=8 Feb 6, 2017 - U-Drive is one of the most capable application on your iOS device. It allows you to organize files from iPhone to external accessory. Features
uDRIVE mini ' Official Apple Support Communities
https://discussions.apple.com/thread/7634399?start=0&tstart=0 Q: uDRIVE mini. When connect the uDRIVE to my iPad, I get "can not use device" device requires too much power! A 1416. Posted on Aug 10, 2016 8:34 AM.
uDrive Mini + iPhone 6S Plus - YouTube
? 0:30
https://www.youtube.com/watch?v=mxTqhjKvR-0
Jun 20, 2016 - Uploaded by Matthew Chen
uDrive Mini Test with iPhone 6S Plus. ... uDrive Mini + iPhone 6S Plus. Matthew Chen. Loading ...
uDrive mini + iPhone 5 Test - YouTube
? 1:27
https://www.youtube.com/watch?v=pYa77DxbvyQ
Jun 21, 2016 - Uploaded by Matthew Chen
??uDrive mini + iPhone 5 Test. ... New App for uDrive (iPhone IOS OTG, schedule to launch on June ...
[Apple MFi Certified] Flash Drive for iPhone iPad [USB 3.0], GMYLE ...
https://www.amazon.ca/Certified-GMYLE-Expansion-Lightning.../B01FXF1DXO [Apple MFi Certified] Flash Drive for iPhone iPad [USB 3.0], GMYLE External Storage ... iPhone 5, iPad Air 2, iPad Air, iPad (4th generation),iPad mini4, iPad mini 3, iPad .... *Please search U-Drive on App Store if the installation does not start ... I was able to save all the photos and files on my iPhone onto the flash drive and ... udrive mini with my IPhone Google Search
Apr 16, 2017 | Cell Phones
When I try to engage Siri she says she cannot make the connection and I should try again later. I have iOS 10.0.2 installed. I have shut it off and restarted but the problem remains
Siri troubleshooting: Siri's not working at all on my device. Which iPhone/iPad models can run Siri? If Siri isn't working for you, the first thing to check is your model of iPad or iPhone - older devices can't run Siri, even if they update to a newer version of iOS. Siri is available on the iPhone 4s and later, on the iPad 3, iPad 4, and all iPad Pro, iPadAir and iPad mini models, and on the 5th- and 6th-gen iPod touch models. Plus the Apple Watch and 4th-gen Apple TV, of course Siri troubleshooting: How to turn Siri on If it's not working at all, Siri might be switched off. Go to Settings > General > Siri and make sure the top slider (next to Siri) is on, and green.
Sep 29, 2016 | Apple iPad Tablets & eReaders
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Aug 30, 2016 | Apple iPad Mini
My IPad mini is showing info when I open it -disabled try again in 60 minutes, how do I fix it
you need to connect your iPad to a computer that has iTunes then hard reset it by pushing the sleep /wake and home button till you see the iTunes logo on your phone, then you'll see and option on the computer screen to restore, then click restore then wait for it to finish, then you can setup your device like new
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Jun 23, 2016 | Apple iPad Mini
Stopped charging at 32%. Now cant access internet or turn off Ipad. Why?
Have you tried this?
Restart your iPhone, iPad, or iPod touch - Apple Support
https://support.apple.com > en-gb
9 Dec 2015 - Press and hold the Sleep/Wake button until the red slider appears. Drag the slider to turn your device completely off. After the device turns off, press and hold the Sleep/Wake button again until you see the Apple logo.
Jan 28, 2016 | Apple iPad Mini
How do I find the IMEI code for a mini iPad?
Find iPad Mini IMEI number:
Navigate to settings-general-about, and scroll down to view your device's IMEI number and other details.
Device body and packaging
Check the back case of your iPad, and you'll find the IMEI number printed near the bottom. If you have the packaging too, look for the IMEI number on the barcode label.
ITunes
Connect your device to your Max or PC, fire up iTunes and click on your device name to open the summary. You'll see your devices name and capacity listed alongside an image of your model - simply click the field below the Capacity field once or twice, till it shows you the IMEI number. You can also right click the number to copy it.
How to find your iPhone or Cellular iPad IMEI number
Nov 21, 2015 | Apple iPad Mini
Lost all contacts on iPad mini
If the important contacts in iPad get deleted, you will try to get them back. Restoring iPad with the iTunes backup is the easiest way to recover deleted contacts on iPad mini. If you update your iPhone backups regularly, then you can recover most of the important data from the backup. The restoring process is also easy to be done, and the following tutorial is for the new users of iOS devices:
  1. Connect iPad mini to computer with USB cable, and iTunes will launch automatically. If not, you should manually start iTunes.
  2. iTunes will recognize iPhone and display the iPad icon at the upper left corner. Click the iPad icon.
  3. The control panel of iPhone appears after you click the iPad icon. Click Summary in the panel.
  4. Click Restore Backup in the right part of the window. Then iTunes will allow you to choose the iPad backup, and finish the restore.
Visit here to know more methods about iPad contact recovery.
http://www.leawo.org/tutorial/how-to-recover-deleted-contacts-on-iphone-6.html
Nov 11, 2015 | Apple iPad Mini
How do i prepare a mini pad to sell so that the new owner can set it up
Use iTunes to restore your iPhone iPad or iPod to factory settings
Restore your device
    1.Connect your device to your computer using the cable that came with it.
    2.Select your iPhone, iPad, or iPod when it appears in iTunes.
    3.In the Summary panel, click Restore.
    4.Click restore again to confirm that you want to restore device to factory settings and delete all data and content.
    5.After your device is restored to factory settings, it will restart. When it does, you'll see the "Slide to set up" welcome screen.
Oct 04, 2014 | AOL AIM for iPad
IPhone deletes my contact names when I sync it to computer! Leaves the numbers, delete only names.
If you've set up automatic syncing, iTunes syncs your device by default whenever you connect your iPod, iPhone, or iPad to your computer. If you don't want iTunes to sync your device without being prompted, you can change this setting.
You can prevent unprompted syncing for any specific iPod, iPhone, or iPad; or for all iPod, iPhone, or iPad devices you connect to your computer.
To prevent unprompted syncing for a specific iPod, iPhone, or iPad:
  1. Connect your iPod, iPhone, or iPad to your computer.
  2. In iTunes, select your device (below Devices).
  3. Click Summary, and then deselect "Open iTunes when this Device is connected."
To prevent unprompted syncing for all iPod, iPhone, and iPad devices:
  1. In iTunes, choose Edit > Preferences.
  2. Click Devices.
  3. Select "Prevent iPods, iPhones, and iPads from syncing automatically."
    If this checkbox is selected, any connected iPod, iPhone, or iPad won't sync without being prompted.
To sync your iPod, iPhone, or iPad when unprompted syncing is disabled, connect your iPod, iPhone, or iPad to your computer, and then choose File > Sync "Device Name" in iTunes, or click your device (below Devices) and then click Sync.
For more information, see the iPod, iPhone, or iPad User Guide or the Apple Support website.
Dec 18, 2012 | Cell Phones
Windows 7 no detecta mi Ipod A1236, al ingresar a la busqueda de los dispositivos Windows me muestra el Ipod con un error que dice "Unknown Divice" no funciona correctamente, ya trate de...
iPhone iPad or iPod not recognized in iTunes for Windows
Si conecta su dispositivo a su computadora con un cable USB e iTunes no reconoce su iPhone, iPad o iPod, obtenga ayuda.
Cuando iTunes en su computadora no reconoce su dispositivo conectado, es posible que vea un error desconocido o un error "0xE". Si lo hace, siga estos pasos e intente conectar su dispositivo nuevamente despu?s de cada paso:
Aseg?rese de tener la ?ltima versi?n de iTunes que funcione con su computadora.
Compruebe que tiene el ?ltimo software en su Mac o PC con Windows.
Aseg?rese de que su dispositivo est? encendido.
Si ve una alerta de Confianza en esta computadora, desbloquee su dispositivo y toque Confiar.
Desconecte todos los accesorios USB de su computadora, excepto su dispositivo. Pruebe cada puerto USB para ver si funciona. Luego prueba con un cable USB Apple diferente.
Reinicie su computadora y iPhone, iPad o iPod.
Intente conectar su dispositivo a otra computadora. Si tiene el mismo problema en otra computadora, comun?quese con el Soporte de Apple.
If you connect your device to your computer with a USB cable and iTunes doesn't recognize your iPhone, iPad, or iPod, get help. When iTunes on your computer doesn't recognize your connected device, you might see an unknown error or an "0xE" error. If you do, follow these steps and try to connect your device again after each step:
  1. Make sure that you have the latest version of iTunes that works with your computer.
  2. Check that you have the latest software on your Mac or Windows PC.
  3. Make sure that your device is turned on.
  4. If you see a Trust this Computer alert, unlock your device and tap Trust.
  5. Unplug all USB accessories from your computer except for your device. Try each USB port to see if one works. Then try a different Apple USB cable.
  6. Restart your computer and iPhone, iPad, or iPod.
  7. Try connecting your device to another computer. If you have the same issue on another computer, contact Apple Support.
Feb 14, 2018 | Car Audio & Video
Monster Iclarityhd Bluetooth Speaker System - Clarityhd Clarity Iclarity Hd Logo
Top Monster Audio Players & Recorders Experts
Lawrence Oravetz
Phillip Hicks
Phillip Hicks
Bill Boyd
Are you a Monster Audio Player and Recorder Expert? Answer questions, earn points and help others
