When i turn my tv on it wont do anything except flash blue and black, do you know what the problem is and how i can solve it?
    Master:
  • 706 Answers
I believe your screen has gone bad. Contact TV repair shop for assistance
Posted on Dec 05, 2014
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
Television stuck on black philips screen will not do anything except flash off and back on to same black philips screen.
Sounds like the media/main board is going out. You can change those out really easy with just a screw driver.
Check ebay with your part number off the board. Start with you tv model number and the the BOARD part number. Alot of board look alike but there aren't.
Also..
shopjimmy.com is a good place.
Good Luck.
Sep 11, 2015 | Philips Televison & Video
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
Hi, I have an Alba LCDW16HDF TV and the blue light on the front keeps flashing but it wont turn on. consulted the manual and it looks like a sleep mode, but i cant do anything with it as it stays...
if thats what your dad did, then maybe theres a dry joint on the circuit in side, iv stripped my grandads down and am currently looking fro problems now, will let you know if i find anything.
Oct 28, 2010 | Televison & Video
My sega flashes on screen but wont come on
Video game cartridge terminals and the console connector pin require servicing similar to this service.
Please let me know how I may assist further.
Apr 19, 2010 | Sega Genesis Console
Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
Jun 17, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
Tv screen stays black with the blue light and two red lights blinking
I have the same problem, if anyone has a solution PLEASE mail me at macry2121@aol.com
Apr 04, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Blue crt assmbly maybe?
its very possible that the blue CRT is horting the set out. Heres how you can test it. Remove the speaker grille and access panel behind the grille and you will see the crts. remove the blue crt circuit board from the end of the blue crt and make sure it isnt touching anything then try powering up the set if it doesnt shut down then you have found the problem and you will need a new crt. or you can switch the blue circuit with the green and try it iwth the blue on green and the green on the blue then if the screen turns green before shutting down you will know that its a problem in the blue drive circuit and not the crt. lety me know if you need further assistance.
Apr 01, 2008 | Toshiba 46H84 46" Rear Projection...
TV Problem with shutting off by itself
Mine just did the same thing.  Except for it was green instead of blue.  The service manual states 8 flashes from the light stands for an overvoltage.  After reading the manual for a bit I realized the bottom row of 3 adjuster screws from behind the speaker grill adjust the output for the red, green, and blue colors.  BEFORE OPENING ANY TV OR MONITOR PLEASE KNOW THAT THE VOLTAGE INSIDE CAN KILL YOU EVEN IF UN-PLUGGED so please be careful and only adjust what is mentioned here.  I un-plugged the tv, removed the grill and the board covering the internals, and carefully turned the 3 adjustment screws all the way down.  I then waited about 10 minutes (don't know if this made a difference).  I turned on the tv, turned the channel to an auxilary input (for a black screen), and slowly raised each of the 3 bottom screws one by one up clockwise until i could see a faint green, blue, or red line (depending on the screw), and then turned each one back a hair until the screen was black again.  Only adjust one at a time, the order for colors are blue, green, then red from the left.  I hope this fixes your problems.  Be careful when working inside a tv,  I suggest not using a screw driver to adjust the screws due to the possibility of it slipping and someone getting hurt.
Sep 16, 2007 | Sony KP-51WS500 51" Rear Projection...
Mitsubishi black diamond tv
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Apr 07, 2007 | Mitsubishi VS-1250 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
