Question about Eyemax Ir-6140fv Security Camera 650 Tvl 40 Smart Ir Led, 3d-dnr, Icr True D/n
Connecting my Seceptre 40, v93cenew with my satilite reciever. x405HDTV
Hello, I have a model 1350 and it seems locked up and will not recieve satilite signals?
Try giving your unit a firmware update using Garmins WebUpdater software, it can be obtained from this link http://www8.garmin.com/products/webupdater/howtoinstall.jsp. If this dosent work your units GPS receiver is probably dead and should be sent in for repair.
Hope this helps!
Feb 18, 2011 | Garmin nvi 1350T 44 in Car GPS Receiver
I just bought Samsung pn58B550. I have connected
go to the service mode , tv off then mute 1 8 2 power
Feb 27, 2010 | Samsung Televison & Video
Is this TV digital ready, or do we need a converter box?
No, it is not a digital ready television. You will need a box if you are planning on using an antenna with it.
If you have it hooked up to cable or a satilite reciever then you don't need a box. It will continue to work like it is now.
Jan 24, 2009 | Orion Televison & Video
IS MY TV DIGITAL?
yes you will. either install an outside antenna or get a good amplified indoor antenna. try your old antenna first, but when your picture freezes or it says something like " weak signal " you will need that new antenna
Jan 24, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Connecting mt digital converter box
Antena will go into converter box input then out of the converter box output into the satilite boxes antena input then out to tv!
Please rate this response and help keep this area FREE!
Thank You!
Jan 22, 2009 | Televison & Video
Satelite reciever
I assume Dream Satellite was charging you for the use of the receiver. At any rate you will need a valid SMART card that is activated by Dream. I assume that you did not cancel your subscription also. If this happened only after the new receiver was installed you could have a bad receiver but more than likely the SMART card is the issue. Contact Dream and see if they can send you an updated one.
Sep 04, 2008 | Televison & Video
Best Way ti connect a Denon AVR-1602 Surround Sound system with a Bell Express View Satlite reciever and Plasma TV
lets see, 3100 has no digital out, so you need analog inputs for the audio. Best picture with the 3100, use S-video. Digital input for the DVD sound and S-video in for picture. OOPS....does your TV have a S-Video input ?. If not then you have to use the RCA standard video type connector, as this particular denon doesnt do up or down conversion to or from S-video to old style RCA.
Sorry for the late response.....Rob
PS.....the HD bell wont do you any good with this receiver nbecause it doesnt have component video inputs. Enjoy Bells' superior picture with regular TV . Its way better than cable. Rob
Feb 03, 2008 | Denon AVR-1602 Receiver
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Eyemax Ir-6140fv Security Camera 650 Tvl 40 Smart Ir Led, 3d-dnr, Icr True D/n Logo
29 people viewed this question
Top Eyemax Cameras Experts
Steve
Are you an Eyemax Camera Expert? Answer questions, earn points and help others
