Question about Whale Gulper 220 Shower Waste and Bilge Pump, gulper 220 shower/ bilge pump
We have a wet room with a mira ATL shower which is linked to the gulp pump. the system is no working, however it was working yesterday. can you help with our problem
This pump works with our Mira ATL Advance thermo shower, but we can not shower as the shower will not come on.
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
Mira shower manuals
If you have water with head removed, Remove and soak shower head overnight in vinegar to remove hard water deposits.
Jun 09, 2014 | Home
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
I have a Mira Vie electric shower, the pull cord no longer lights up, and therefore my shower won't run. I've checked the fuse box and nothing is labelled, it's an old style fuse box. Ther
Buy a current tester( under a tender) and test if supply is going to pull cord (remove the 2screws on cover of pull cord. )Ifyou have power then it's you pull cord that needs replaced if not its mains fuse
Sep 26, 2012 | Home
I just bought the GE Shower Water Filtration System and i have a handheld shower head. Will that work for it or does it only work for a normal shower head?
Only on normal head.If you have normal set-up hand held diverts before filter.From the stand point of a 35 yr master plumber,your wasting your money,unless you gulping a lot of water while you shower.Lots of gimmicks out there,like drain cleaning chemicals complete waste of money
Jan 26, 2011 | Home
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
My mira sport electric shower keeps overheating and no longer provides hot water. What shall i do? Please help...
Sounds like the heater tank is failing. Try ringing Mira Customer Service on 0844 571 5000 who have Engineers who can repair your shower at a competative fixed price
Jan 16, 2010 | Kitchen Appliances - Others
Does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
Jan 31, 2009 | Home
Shower goes hot and cold
If you are having trouble only at the one fixture (shower), and no where else, the problem is most likely in the shower valve...which either needs new cartridges, or a complete replacement.
hope this helps
Jan 08, 2009 | Home
Whale Gulper 220 Shower Waste and Bilge Pump, gulper 220 shower/ bilge pump Logo
47 people viewed this question
Top Whale Plumbing Experts
Paul Carew
Tom Chichester
Are you a Whale Plumbing Expert? Answer questions, earn points and help others
