Question about Acer Tablets & eReaders
Won't charge a tablet
This will not charge my acer a1-810 at all the pack seems to short out when I plug it into the tablet.. I then have to charge the pack all over again..
  • Mike MacDonald
    Mike MacDonald Dec 05, 2014
    correction it is an acer a1-830
    Sergeant:
  • 333 Answers
The charger might be defective and not capable to deliver the required current to charge the battery, try a replacement charger.
Posted on Dec 05, 2014
Testimonial: "i had only bought these because, I am going to ireland for 2 weeks....and needed something to keep my appliances charged..."
Tip
Power Cable Popping Out on Versus Chinese Tablet
Versus Tablets (sold mostly in the UK and Ireland until 2014) have some great features (like HDMI out and Bluetooth), but power is a problem. They do not charge through the USB port, but through a 3.5mm barrel jack plug (specs are 5v 2000mA).
The power cable on my Versus Android Tablet keeps popping out (and therefore the tablet won't charge). Lately it got so bad that the plug simply wouldn't go in at all. I did a bit of research and came up with a fix.
There's a small plastic ring at the top of the plug. Take a precision pliers and pull the ring off the plug. BE CAREFUL! - If you damage the plug it simply won't go in at all, and your tablet will be useless.
Without this ring the plug stays in and the tablet charges. It still pops out occasionally, but a lot less than it did before.
NB: I do see some replacement power adapters with these plugs available on eBay and Amazon, so you may be able to try out a replacement power supply too.
Versus Tablet
on Feb 01, 2015 | Tablets & eReaders
I have trouble charging a Acer icona one 7 tablet, any ideas?
first of all these tablets take a long time to charge. second check the cable were you plug into tablet to make sure the holding clips are working and take hold. My first choice and most inexpensive is to buy a new charger. Also check plug in port for damage. look at warranty to see if it is still covered and get replaced. />
Feb 06, 2015 | Tablets & eReaders
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
Tablet won't charge
If it's new bring it back on the warantee, if it is out of warantee, check to see if the power supply is putting out the proper voltage at the plug in tip to the Acer. Make sure the tip is put ALL THE WAY into the hole on the acer.
Jan 02, 2013 | Acer Iconia Tab A200 Series Tablet with...
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
My acer charger got wet, I thought I dryed it off good. I plugged up my tablet and heard a click now it won't charg up( my tab)
You could go to the place you bought it or another tech store and see if they have another tablet like yours lying around so you could test out and see if it is just your power cord that needs to be replaced. Because most likely it's time to buy a new power cord. Hopefully you didn't fry the tablet's motherboard also that's why you should test out the power cord first.
May 28, 2012 | Acer Tablets & eReaders
My galaxy tablet just went dark. No screen or power. It was more than 50% charged last I looked an hour before. It has been plugged in for 20 minutes now and it won't turn on. What happened??
it depends.. check the battery pack maybe this cause a over charge and check first if your galaxy tablet is still part of the warranty this will help you a lot.
Dec 09, 2011 | Samsung Galaxy Tab Tablet PC
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Tablets & eReaders Logo
108 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
