Question about Toshiba 50L5200 50-inch LED TV
How do we fix the wire that connects the color wheel to the tv
Broke the wire
    Top Expert:
  • Toshiba Master
  • 74,251 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 05, 2014
TY-LA 1000 loose wire
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Feb 21, 2014 | Panasonic TY-LA1000 Projector Lamp for...
Makes noise around light and will not come on.
yes a broken color wheel can prevent a set from powering up but a broken lamp could also shatter and have pieces near the color wheel.
Aug 07, 2012 | Zenith Z52SZ80 TV
Have a Samsung HLR5067Wax, I replaced the bulb, however when the TV turns on the picture is distorted and pixelated. What can cause this?
U recheck all the input and output wires connections take out and put back in for the replacement of the projection lamp?The tv colors wheel might be also dead too.Picture now,flashes colors or black&white within the picture itself?Any humming or motor noises,any these causes are the colors wheel is dying,require replacement of the tv colors wheel.
Dec 15, 2010 | Samsung DLP HL-P5663W 56" TV
Color Wheel
I'm pretty sure if the color wheel spins with no vibration that it's not the colorwheel. I would have to say that your cable is bad. If it has been bent repeatedly near the connection that the wires could be breaking down. Try a brand new cable.
May 06, 2010 | Panasonic PT-D4000U Projector
My tv, just shut off! the screen does not turn on, and makes a squealing noise! what is wrong?
That is the classic case of the color wheel going out on you. The color wheel has ball barrings that tend to break and cause friction within the wheel. It'll start squealing loudly when it becomes stuck. Before it broke, did you notice the color going out or a fuzzy picture with poor skin tones? That's the color wheel!
Feb 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Test
Ballast Lamp provide back light in DLP TV and if its bad / broken TV wont power up. If lamp is weak, dark or less bright picture will come in screen. Color wheel is responsible for colors in picture and if its broke, TV wont power up and common problem with color wheel is high pitch noise while it spins.
Jun 12, 2009 | Sharp 65DR650 65" Rear Projection...
Anyone have a sevice manual? I need a part number for cable.
Send an email to the address below with as much descriptive info as you can and ask for the part number, availability and cost. They will research it for you.
CETechSupport@encompass.com
Encompass is a parts distributer in the US that supplies parts for Samsung.
Dan
Apr 22, 2009 | Samsung HLN5065W 50" Rear Projection...
How do I replace the "color wheel" in this T.V.? (I have new one)
First you have to remove the Optics Engine itself, Locate the lamp housing and remove the lamp, the color wheel is attached to a large grey or black heat sink looking device, with two screws holding it in place. Look for a copper colored flex cable, and a small three wire plug connection to a Aluminum container. Trace these wires form the container which is by the way called the DMD Module. Tracing the wires will lead you directly to the color wheel assembly. Remove tthe two screws holding the color wheel in place and lift up gently, their is also a rubber seal around the color whee housing that needs to be replaced also but should come with the new wheel.
Mar 14, 2009 | Samsung HLN507 50" Rear Projection...
Bad Color after replacing Color Wheel, removing jumper wire did not fix it
after removing jumer, all is perfect.
jumper is inside an opening abut 3/4 inch under label, remove what looks lie rubber.
Oct 03, 2008 | Samsung HL-P6163W 61" TV
Broken Wire
Which color wheel were you putting in?
250a or 674a
Tv Coach
Dec 11, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Toshiba 50L5200 50-inch LED TV Logo
Top Toshiba Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Electro Med Services...
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
