Question about Fujitsu Computers & Internet
Why is my laptop screen dim
Power options
  • Anonymous Dec 06, 2014
    hi if this is the case its something wrong with the backlight inverter board or the CCFL tube inside the lcd panel has a bad connection or is a bad tube this tube can be replaced its a delicate job though ... but can be done i would go on the side of the CCFL tube is bad {end of life} Bgrade stock uses 20,000 hrs tube and Agrade 50,000hrs so youll find the correct ccfl tube for it on ebay but hay it could just be a bad connection put it on in low brightness and you can most often smell ozone {photocopier smell} from the lid if you smell this then its a bad connection i plump for one of the ccfl is bad most often LCD panels in laptops use 2
Try too use the fn key and look on the function number keys for like + - and a little round sun
this increases the brightness when you press fn in and press like F3 on my machine its F3 + F2 -
Posted on Dec 05, 2014
Testimonial: "I've already tried that. The thing is if I keep on starting eventually I get a bright screen and it will remain until I shut down or restart."
Screen is dim when power not plugged in
In power settings you will find the dim adjust, Your laptop has power settings you can adjust to your preference. That said, the default settings are usually set to a power saving that means when you unplug your laptop from th AC source your laptop will dim to the power savings settings and prolong battery life. Look in power settings by right clicking the power icon in the taskbar notification area and open the power options. There are many options to choose from I use High Preformance, but on battery it shorten battery life. If you need assistance just respond to this solution.
Nov 05, 2012 | Samsung NP-N110 Netbook
My laptop has a dim screen.. It turns on with normal coloring but once my laptop is fully on it dims. How do I fix this?
Check the setting in the Power Options for the display. It sounds like the power savings setting is very short and needs to be changed.
Click Start>Control Panel>Power Options
Let me know if this solves the problem. Thanks.
Mar 31, 2011 | Computers & Internet
Dim lighting
You need to configure the power options.
Go to control panel and then click on power options.
Select advanced power options and there select the power mode as balanced or high performance.
Jul 20, 2010 | Acer Aspire 5100 Notebook
I turn on my laptop and it's dim. I press the FN
This is a Function of the laptop,you need to adjust your Power Settings. See the PC, does that to save Battery power, it will always be brighter, generally, on the Wall supply. You may need to set up a profile for both.
Apr 01, 2010 | Acer Extensa 5420-5687 Notebook
Screen dims on the HP Compac nc6400 when on battery.
Hello Artemis,
My name is ArmyMason and I think I can help you with this. Their is two different ways of getting around this issue. One is turning up the back light via your keyboard. Their should be a blue picture of a sun with an arrow pointing up, mine is on the F10 key. Hold down the FN key and tap the up sun key until you get the desired brightness. The other solution is take the computer out of laptop mode. You can do this by right clicking on your desktop and choose properties. Click the Screen saver tab and then click the Power Button. Change the power scheme to Home/Office Desk and click Apply. Now when you are on battery power your computer sceen shouldn't dim and your processor should also run at full speed if you choosed to do the second option.
Thanks,
ArmyMason
Feb 23, 2009 | HP Compaq NC6400 Business Notebook
Display brightness
Ok on your keyboard there should be some way to adjust the brightness just plug in the laptop and adjust it to what you want then unplug the laptop and adjust it to what you want and it should keep that setting. if that does not work you can check the bios settings some laptop bios' have a brightness option.
Dec 06, 2008 | HP Compaq Presario R4000 Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Screen goes dim intermittently
By defult this is a power saving option. click on yr batt on toolbar to see more options
Dec 05, 2007 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
49 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
