2009 Chrysler PT Cruiser Logo
Marylin Ingram Posted on Dec 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2009 PT Cruiser not Turbo charged; yesterday while stopped at a store I noticed that a stream of water was coming from under the car; the water was clean and I have 50/50 anti-freeze in my
I just purchased 50/50 green anti-freeze and put in vehicle, it had 50/50 orange anti-freeze; is this a problem?
scott kudick
Level 2:
Sergeant:
Champion:
  • Expert 242 Answers
  • Posted on Dec 05, 2014
scott kudick
Expert
Level 2:
Sergeant:
Champion:
Answers
242
Questions
Helped
47674
Points
681
Orange is extended life anti freeze when you change you should drain and flush system. clear water under car might be air condition water.
A
Anonymous
The water is coming from perhaps the washer bottle
if its not the coolant then its gota be coming from showhere
1helpful
2006 Chrysler PT Cruiser, 2.4L, non turbo motor. Which 20 amp fuse does the wiper motor use please?
Question edited for clarity.
Question moved to model category.
Fuse 15. 20 amp, yellow.
Fuse Box Diagram Chrysler PT Cruiser (2001-2010)
https://fuse-box.info > chrysler > chrysler-pt-cruiser-20...
Fuse box diagram (location and assignment of electrical fuses) for Chrysler PT Cruiser (2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010).
My 2004 pt cruiser shut off and will not even try to start. Shut the car up and came back next day and the alarm will not stop sounding. What can be the cause and how can i fix these problems?
2001 PT Cruiser Cuts Out, Engine dies for no reason ...
? 2:04
www.youtube.com/watch?v=cG9qCHfBhGw
Jan 10, 2014 - Uploaded by michelle salazar
2001 PT Cruiser Cuts Out, Engine dies for no reason ... picked it up on October 18, 2013 only to have it die on me while on the interstate. After it ...
Turn off alarm on 2009 PT Cruiser - PT Cruiser Forum - PT Cruiser ...
www.ptcruiserlinks.com > ... > Sound and Security Forum
Aug 18, 2013 - 10 posts - ‎8 authors It's not an add-on alarm, it's just the factory alarm. ... then I go in to panic mode (because it's horribly embarrassing when it goes off and won't shut off) and try everything else - like pressing the lock button, ... 2004 Pt Cruiser GT Car alarm installation, operation, problems and solutions ...
May 17, 2013
KEYLESS ENTRY stop working
Nov 1, 2009
How to reset Security.....
Apr 26, 2009
Programming the keyless Remote
Mar 13, 2005
More results from www.ptcruiserlinks.com
Pt cruiser sputters when ac is tyrned on
chances are you have a secondary miss under these conditions try replacing your spark plugs and wires.
cheers
Oil in water I have a 2005 PT cruiser 2.4 turbo I
did you bolt all in the right order from the middle to the outside.
and is the enginehead cheked out in special store.
this is hardly to be done at home.
2003 turbo pt. cruiser check engine light on/off smell gas driving sluggish what the problem
Pull in to an Autozone, Napa, or similar big parts store and they will scan for codes free of charge. 9 chances out of 10, that code will direct you to part required for repair. That's why they scan for free. Much easier and cheaper that way.
Blown turbo 2005 Chrysler PT Cruiser
indicates a turbo failure
remove it and have it overhauled/inspected
1helpful
Grommett fell down intercooler charge-pipe on my 03 PT Cruiser. if I disconnect upper charge pipe and rev engine/spool up turbo will it blow grommett out or do I have to disconect the whole thing to locate...
If it was my car I would be tearing it down because I couldn't afford to buy a new turbo. Maybe it will come out if you spool up the turbo but if it doesn't there will be a new turbo in your future. Hope this helps.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Chrysler Expert? Answer questions, earn points and help others
