Question about Brother Hl-2250dn 2400 X 600 Dpi Laser 26 Ppm 7 S 85 S 32 Mb
Drum light indication and error light indication is on
    New Friend:
  • 4 Answers
The drum and error light being on may be due to the drum life being up or a missing drum. Re seat the drum and then reset the drum life timer as below. If this gets it back to working condition, remember to stock up on a spare drum. An oem drum can most likely be used a couple times but they will wear down and the opc coating will come off the drum and cause bad streaks/print on the output.
Brother HL-2250DN Drum Counter Reset
  1. Turn on the printer (assuming it is not already on).
  2. Open the front cover.
  3. Press and hold the GO button for 4 seconds or until all the LED's light up.
  4. Release the GO button and close the front cover.
Posted on Sep 01, 2016
  • 778 Answers
Hello, Sounds like you need a new drum or maintenance kit for the laser. You need to call your maintenance provider for repairs or take to a computer/office supply repair shop.
Posted on Dec 12, 2014
Should the drum light always be on?
http://download.brother.com/welcome/doc002127/ZLe_UG_eng.pdf
The manual will tell you that when the Drum light is on, that indicates Drum Life near end. Prepare to purchase a new drum very soon. I have added the link for the manual because it has the error codes listed. Good luck and make sure you read the pages on Replacing Drum before you begin.
Jul 10, 2014 | Brother HL 1440 Laser Printer
My brother HL-2170W have a flashing error and drum light. When the printer starts up, its stops in the middle as if a paper is stuck but I can't find anything.
Hi There,
The Drum LED and the Error LED alternates turning on and off.
Meaning of LED Indication
Drum error:
The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Please click on YES if this helps,
Thanks,
Vikroks
Mar 23, 2011 | Brother HL-2170W Laser Printer
Drum error
with the front cover still open press "clear/back." it will ask if you are replacing the drum unit. press the up arrow to indicate yes. wait till it says accepted and then close front cover
Jan 24, 2011 | Brother DCP-7040 Laser Printer
Error drum or drum light on and off. what do I do?
The Drum LED alternates on and off, turning on for 2 seconds and off for 3 seconds,and the Ready LED is on.
the LED lights indicate the drum unit is near the end of its life. I recommend that you get a new drum unit to replace the current one.
Jun 05, 2010 | Brother HL 2140 Laser Printer
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Brother Printer HL 5250DN
A solid red STATUS light with a solid yellow TONER light indicates toner out...replace according to pg. 63 in the manual.
It can also indicate a cartridge position error. Take the DRUM UNIT out of the machine and re-install.
A solid red STATUS light only means:
Front cover open
Fuser cover open
Dust on drum
Too many trays
Buffer error
Print overrun
Memory full
Download full
Font full
See pg.48 ofthe manual.
Oct 02, 2009 | Sport & Outdoor - Others
HL-1240, the alarm light is on, what would be the reasons?
the first alarm light (at the very top) indicate the toner life ends the second light(middle) indicate the drum life ends and the third is for paper jam or print error
Sep 18, 2009 | Brother HL 1240 Printer
Brother Laser HL-5240 has a status light and toner light. Fuser was replaced but no help.
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
Jun 25, 2009 | Brother HL 5040 Laser Printer
Oki C5450 error message
The figure after the K drum Life tells you how much life there is left on the BLACK (K) drum. C indicates Cyan, M indicates Magenta and Y indicates Yellow.
Go to the USAGE MENU and look at the K DRUM LIFE setting. This will be a 2 digit percentage value. As you have just seen the message appear this will mean that the drum life remaining is ....whatever the 2 digit value displays.
The life expectancy of a drum is approximately 15,000 pages.
Jun 08, 2009 | OKI C5400 Laser Printer
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
Oct 19, 2008 | Kyocera Mita FS-1920 Laser Printer
Brother Hl-2250dn 2400 X 600 Dpi Laser 26 Ppm 7 S 85 S 32 Mb Logo
62 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
