Question about YLMart Acer Aspire V5-551 Keyboard Cover
Acer V5-552 Will not turn on even when connected to power lead
Can't try much as blank screen and not re-acting to anything?
GETTING THE DISPLAY TO WORK
try holding down power button for thirty seconds on laptop.
once you think it is off remove power lead and remove battery.
place battery back in and power cord
Try pressing power button on laptop
see if anything is displayed on screen at power up
see if operating system loads correctly
suspect laptop locked up and needing a full shutdown
Jul 30, 2016 | Computers & Internet
I have a Acer Aspire 5610. A few days ago I turned it on and the screen stayed blank/black witha full battery. After trying a few times of trying this I plugged in the power lead and tried and it worked....
could be damaged, try calling geek squad or taking back where you got it. when my dell acted up i called them directly despite purchasing from best buy. they didnt charge me a dime.
May 06, 2011 | Computers & Internet
Acer Laptop Black Screen
Just to be clear this is not a fix for screen problems, this is a fix for a problem that prevents the laptop from booting at all. The laptop would not even attempt a POST and so would not even get as far as trying to output anything to the display.
I'm no expert but just wanted to share a fix that worked for me. For me it was a problem with the laptop not coming out of hibernation properly and completely freezing, the only option was to power off. On reboot nothing would happen, the screen would not even be initialised so it is nothing to do with the screen.
I can only theorise what the problem may be. As the solution is to remove the power lead, remove the battery and hold down the power button it would seem to be an issue with the laptop retaining some residual charge which is preventing the laptop from booting. I've heard of other poeple who have managed to fix this by simply letting the battery run out and then leave it overnight, this will again dissipate any residual charge but is just a much slower way of doing it. Holding the power button down with no power sources attached will dissipate this charge and allow the laptop to boot when a power source is reattached.
Unfortunately if the laptop boots and the screen is blank then it is a different issue, if the image on the screen is faint it is most likely a problem with the backlight and in these instances this fix will not work. Before posting this I thought this was an isolated incident but there have been so many replies it would appear to be a more common issue than I thought and works on many different models, not just the DV6599 that I've tried it on
Jun 01, 2010 | Acer Aspire 1642ZWLMi Notebook
Acer aspire 5535 hibernation blank screen stuck
it might be your harddisk you should check it first it may not be loading your o/s or unbootable partition
Sep 08, 2009 | Acer Aspire 5535-5050 Notebook
Completely blank screen when power is on.
do a hard reset....remove charger>remove peripherals>remove battery> press and hold the power button for about 30secs, while batt and charger is removed> then plug in the charger only and turn ON!
Please vote, thanks!
Jun 27, 2009 | Acer Aspire One Netbook 8.9" Notebook
Blank screen
try without the battery connected
Mar 22, 2009 | Acer Aspire One PC Notebook
Blank screen
Seems like the connection might not be setup correctly inside the laptop. Check for bent pins for where the lcd screen connects to the motherboard, and also make sure any "ground" screws are in like they were if there are any.
Mar 20, 2009 | Acer Ferrari 4000 Notebook
Laptop won't boot up properly
Connect your computers to an external monitor and press the appropriate F key combination (Shift + F7) to switch video output to the monitor. If you see an image on your monitor you have a bad LCD screen or back light inverter. If not you need a new motherboard. Guy that gets ticks, you need a new motherboard anyway.
Feb 18, 2009 | Acer Aspire 9300 Notebook
Screen picture froze, powerd down, powerd up, blank screen
open cbinet of crt,
then internally check circuit connection.
or check for external lead connect very well or not ,one of power,and data cable.
Jan 25, 2009 | Acer Aspire 5100 Notebook
BLANK SCREEN-ACER ASPIRE 3661
You can check the little indicator light on the notebook.
If the hard drive was dead, that wouldn't cause the display to go blank.
If your problem was with your hard drive, you would still get the BIOS screen and then a message about being unable to load an operating system. So, I doubt if that is the problem.
My guess is that you have a relatively serious motherboard, video card, memory, or CPU problem.
When you turn it on, does it beep ? If so, how many times ? You can translate these beep codes at: http://networking.ringofsaturn.com/PC/beep.php __________________
Oct 22, 2008 | Acer Aspire 5610-4648 Notebook
YLMart Acer Aspire V5-551 Keyboard Cover Logo
142 people viewed this question
Top YLMart Cooking Experts
Tom Chichester
ray gallant
Are you a YLMart Cooking Expert? Answer questions, earn points and help others
