Question about HP DeskJet 1220c InkJet Printer
Color printing I keep trying to replace the color printer cartridge, but the printer still won't print documents in color.
  • ANGELMERGZ Nov 12, 2007
    HP DESKJET 3900
  • 417 Answers
Hi I take it that you have removed the blue tape that is over the cartridge when you install it? If you have are they original or refills if refills change for an original.
If you have done the above then remove the ink cartridge and with soft cloth wipe clean the gold contacts on the cartridge and also on the carriage.
When you have done the above try printing again if still not printing then check the following.
  • Goto Start Printers and Faxes
  • Right hand click on the printer Icon
  • Select "Printing Preferences"
  • Make sure that you are set to color
  • Close window the Right hand click on Icon again
  • Select Properties
  • Click on Print test page
  • This should not print in color if color was selected in printing preferences.
I do hope this works for you
Thanks J
Posted on Jan 13, 2008
yooperbud
  • 8637 Answers
SOURCE: Color printer won't print color
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 29, 2009
BelgianAlien
  • 50 Answers
SOURCE: HP Solution Center Screen said:
Have you tried to replace the current cartridge with a new one? It is not uncommon for even a new cartridge to be faulty, It happens sometimes.
Also, look in your printer manual for the procedure on how to run a nozzle/cartridge cleaning and alignment.
If that does not resolve it, take the cartridge out, grab some rubbing alcohol and some q-tips. Put some rubbing alcohol on a q-tip and GENTLY wipe the contacts on the cartridge AND on the contacts in the printer where the cartridge installs. BE CAREFUL! Make sure no cotton from the q-tip gets left behind on either.
Good luck and thanks for using the fixya forums!
Posted on Mar 27, 2009
komguy
  • 2306 Answers
SOURCE: I would like to print black with one color cartridge empty
If you take the empty cartridge out and put a small piece of electrical tape over the little window on the front, the printer will think the ink is full.
Posted on Jul 20, 2009
  • 240 Answers
SOURCE: Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Posted on Nov 28, 2009
  • 241 Answers
SOURCE: hp printer power light keeps blinking -- wont print any document
Turn both your printer and computer off then after a few minutes turn back on. This should cancel the print job.
Posted on May 28, 2010
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
My Pinnacle Pro 901 is set to print using black ink only but it keeps telling me I need to replace color cartridges and won't print.
You won't be able to print if one of the cartridges is out of ink. The printer needs all cartridges with sufficient ink levels to prevent damaging the printhead.
Oct 25, 2012 | Lexmark Pinnacle Pro 901 All-In-One Inkjet...
I've installed color cartridge but it won't print in color
Try to re-insert the color cartridge into the printer and make sure it is properly seated in the cartridge carrier.
If that doesn't help, try to clean the print nozzles. Please follow the steps below:
1. Press Copy. 2. Press Options until Maintenance appears on the display. 3. Press the right arrow until Clean Cartridges appears on the display. 4. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles. 5. Print your document again to verify that your print quality has improved.
Oct 22, 2011 | Lexmark X6170 All-In-One InkJet Printer
I can download solutions center also it keeps showing no color cartridge so it wont print in color
Try to clean the cartridge nozzles. On your printer operator panel, press Setup button, press Ok -> Press the arrow buttons until Clean Cartridges appears, and then press Ok. A page prints, forcing ink through the print cartridge nozzles to clean them. Try to print your document again.
Apr 30, 2011 | Lexmark X4650 InkJet Printer
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Print WITHOUT colour cartridge
If you right click the printer in the Printers section of the control panel and select printer preferences, there should be a tab called maintenance. In this tab, you should find a setting called Ink Cartridge Settings. Once you click on this setting, click black cartridge only. This should allow the printer to only use the black ink and therefore you won't need color.
If you have any other questions or this doesn't solve your issue, let me know.
Jan 10, 2009 | Canon MX300 Office All-In-One Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
HP DeskJet 1220c InkJet Printer Logo
114 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
