Have Solar PVa system with 10 panels on the roof. The Inverter is an Aurora model and displaying error message "Missing Grid", can anyone solve?
Error code "Missing Grid".
  • Frank Alexander
    Frank Alexander Dec 06, 2014
    Forum, thanks for the input but I resolved it myself yesterday. I was looking for some input failure and when I took the bottom cover off the Regeneration Meter (Landis E110) I found that the Load (N) had become disconnected. Reconnected and all working fine again. Many thanks again and a fantastic site for solutions.
  • Frank Alexander
    Now trying to close this!
There is insficient input voltage to permit connection
to the grid: the inverter waits until there is grid
voltage to carry out the parallel connection
look at page 27 here for more info
http://www.hyland.com.sg/download/systemtech/POWER%20ONE%20PVI-6.0-TL/POWER%20ONE%20PVI-6.0-TL%20Manual.pdf
you may have a different model of inverter pvi so youll find the manual
i think your output from the panels isnt enough juce as it says
or the inverter or more likely a fuse has failed
remember this is input voltage and not the connection to the grid thats been autherised
Posted on Dec 05, 2014
The solar panels generating power and the grit electricity supply is cut off. Do I still get electric power without the grit supply ?
depends on the way it is installed and the inverter in use
mostly
no
as the inverter requires the grid to work
talk with the installing electricians as to what you have
Jan 31, 2018 | Solar Electrical Supplies
Tip
What is an IMEON solar hybrid inverter
IMEON hybrid solar inverter technology is the all-in-one solution for true multi-source energy management. Consuming the produced solar power directly, storing it in batteries for later use or for the event of a power failure, injecting to or consuming from the grid only if necessary, is now possible.
IMEON hybrid inverters are a concentrate of technology and innovation. The implementation of an artificial intelligence allows IMEON to understand its environment and to adapt its energy management strategy while respecting the objectives of the user: autonomy, lowering the energy bill, securing the power supply...
The IMEON solar inverters for self-consumption are the heart of your solar system. IMEON displays a genuine consciousness as it learns, predicts, anticipates and adapts its operation using deep learning process, aiming to make the best choices to increase your autonomy. IMEON is the only inverter that anticipates the future. Its unparalleled capabilities, unique in the market, allow it to constantly evolve and accommodate new features, thus increasing its profitability.
autoconsommation maison autonome onduleurs batteries solaires Imeon Energy
on Mar 12, 2018 | Inverter Electronics - Others
Is this true or scam Government pays you to go solar.
The US government WILL NOT PAY you to go solar. There have been incentives on the state level to get people to install solar panels. Most of these have dried up but it is possible to find programs that will reimburse you a portion of the total cost but don't expect much. We live in Florida and in 2009 we were promised nearly 1/2 back if we installed. We got less than 10% when all was said and done and it took 2 years to get that.
Aug 18, 2015 | Miscellaneous
I have solar panels that put out a little more voltage then they are rated at,and they keep faulting out my grid tie inverter.I need a resister to knock down the voltage about 8 volts, got any ideas?
I like to ask, is the voltage from the solar panel messure with some load connected or is open circuit, normally solar panels produce high voltage than the working system, the reasson for that is to have Amperes in of to charge the batery, these is related to the size and power generated by the panel.
No need a resistor or in any case use a voltage regulator to prevent over charge.
Apr 14, 2015 | Inverter Electronics - Others
How do i convert my 1.2kw solar inverter on my roof so i can run my home on stored energy ?
Solar panels produce DC voltage.
some solar panels have the inverter integrated into each solar panel.
I would suggest contacting a local solar panel supplier and asking them if they could add a Battery Charging System to the Solar panels you use. An then what sort of inverter to add to the bank of batteries.
An inverter converts DC voltage to AC voltage to use in the grid.
The AC voltages and DC voltages involved have the possiblity to kill if you much around with electricity.
Jan 15, 2015 | Inverter Electronics - Others
WHY SMA SUNNY BOY SOLAR PANEL INVERTER SAYS ERROR F1-OPEN ?
I suspect strongly that it has an interlock switch on the front panel, and someone has opened the panel and failed to fully close it back up so it's weathertight.
Jul 31, 2014 | SMA SWR 700U SBD Sunny Boy 700W with LCD...
Need installation instructions for aerosharp HR-INV-XOI-030 solar inverter
My HR-INV-X01 PV Invertor LCD Display has nothing. No power, run or fault lights however the blue safty switches note ON. What could be the problem?
Jan 07, 2011 | Solar Grid-tie Budget Package: Panels,...
69 people viewed this question
k24674
jasbo
jasbo
