Question about Life Fitness Exercise & Fitness
I have an older life fitness treadmill and it started and shuddered and then stopped and gave an error 2 message any idea what could cause this?
2 Suggested Answers
bwinton
  • 83 Answers
SOURCE: error 1 message on older life fitness t3 treadmill
Error 1 - Start up error. This is caused because the belt was commanded to move and the opto (speed sensor on the motor) has not seen any movement or the belts movement was interrupted prior to it reaching its commanded speed. To fix Verify opto operation in Diagnostics, Motor Test
Mode, Section 2. Verify DC voltage at connector P6 pins 1 and 2. Verify that LED 4 on the Motor Controller flashes as the motor moves. Let me know if you need any more help. Fitness Fix-It
Posted on Mar 24, 2010
Have twice had the treadmill stop mid session and got the error message - Elevation Direction Error -
You have to check the Elevation limit switch.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Aug 07, 2015 | Life Fitness F1 Foldable Treadmill -...
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    Stuck Key Error Message on Life Fitness F3
    Stuck Key means one keys on the function pad assembly has failed and will need to be replaced. Call Life Fitness @ 800-351-3737
    May 03, 2010 | Life Fitness F3 Folding Treadmill with...
    Error 1 message on older life fitness t3 treadmill
    Feb 17, 2010 | Life Fitness T3 Treadmill with Advanced...
    Fet error message
    The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
    Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
    Life fitness treadmill display: transistor error-won't run
    This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
    Solution
    Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
    Feb 28, 2009 | Life Fitness Remanufactured Next...
    Replace Switch error message
    It was the emergency tag that you attached to yourself when you run (in case you fall over - the belt then stops etc). i had not connected it properly
    Jan 25, 2009 | Life Fitness F3 Folding Treadmill with...
    Exercise & Fitness Logo
    54 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Electro Med Services...
    Matt Olenzek
    Matt Olenzek
    sajeel1978 .
    Level 1 Expert
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
