Question about Orei Dvd-P901 9-Inch Swivel Screen Multi Region Free Portable Dvd Player - 4.5 Hour Long Battery Life - Usb/Sd Card Input
How do I recharge the battery
Don't know how
  • 84 Answers
It has a mains-power supply with a stepped down voltage. which has a jack which fits into the unit. see the illustration. the supply is on the right of the unit.
http://g-ecx.images-amazon.com/images/G/01/electronics/detail-page/B007C9P3PO_portable-dvd-contents-lg.jpg
Posted on Dec 05, 2014
How to charge camera
You don't. The Kidizoom uses four standard AA batteries, either disposable or rechargeable. If you use rechargeable batteries, you must charge them outside the camera using a standard battery charger. Rechargeable batteries and battery chargers should be available at just about any department, electronics, or office-supply store.
Oct 06, 2012 | Vtech Kidizoom Digital Camera
Revive drill driver battery packs
Rechargeable batteries do have a lifespan, they won't recharge forever. If you have fully discharged the batteries then fully recharged them and they still don't have full power or they only last a couple minutes then they are done. If they won't charge or the charger shows them as defective, the only fix is to replace them.
Jan 29, 2012 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do i charge a vivicam 8690
You don't. The 8690 uses three standard AAA batteries. You can use disposable alkaline or lithium batteries, or rechargeable NiMHs. If you choose to use rechargeable batteries, you must charge them outside the camera using a separate battery charger.
Dec 23, 2011 | Vivitar ViviCam 8025 Digital Camera
I bought a 4 pack aa nimh2700 mah brand new sit for a long time without using them now they don't charged what can i to make them work?
  • Rechargeable batteries get old and can loose effectiveness after sitting for a while. You could have a charger problem as well. If you have another charger laying around you can see if the batteries take a charge with a different charger. But, even with rechargeables, they do go stale. If you buy new rechargeables make sure they are "fresh" as buying outdated rechargeable batteries can be a waste of many as many don't work. Buy from a reputable place as well. So many rechargeables from over seas are just not worth a dang.
  • Hope this helps.
Nov 05, 2011 | Cameras
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
I get a green and yellow light on the Ryobi 18v charger and the batteries don't recharge. Does this mean the charger is now bad? Thanks for any help. Dan
This usually indicates that one or more of the rechargeable C batteries is not recharging. The batteries are standard rechargeable C batteries but the terminals are spot welded and are very hard to separate. There are 15 rechargeable C batteries in the Ryobi 18v battery pack. A battery tester will show which battery(s) needs replacing. There are refurbishing centers (Google search) but they will replace all the batteries and usually upgrade the OEM 1500 mah batteries with 2100 mah, or higher, batteries.
Jul 07, 2010 | Ryobi Multi-Volt Battery Charger
My camera's screen is blank. It does not seem to view the scene. It takes black pictures.
Don you hear it function when you press the shutter? Does it start up in any way when you turn it on? Knowing whether or not it is an expensive camera or a more "point & shoot" would be helpful. Are they rechargeable batteries? It coud be as simple as your batteries (rechargeable) have worn out. If it is not the batteries, well, time for a new camera. Batteries are the only thing you can address, provided they are removeable.
Aug 23, 2009 | Cameras
Battery recharge
Motherboard is possibly bad. Try doing a Google search for NEC Versa LXi recharging board.
Jan 06, 2008 | NEC Versa LXi Notebook
Power on problem
Please check the batterries by replacing them with fresh ones. Regards, Ari PS if you want more info please advice.
Mar 07, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Orei Dvd-P901 9-Inch Swivel Screen Multi Region Free Portable Dvd Player - 4.5 Hour Long Battery Life - Usb/Sd Card Input Logo
83 people viewed this question
Top Orei Televison & Video Experts
Are you an Orei Televison and Video Expert? Answer questions, earn points and help others
