It take longer to fill up the water what do we do?
  • 3,592 Answers
Turn off taps on wall and unscrew the hoses. check the tap end of hose see if there is a mesh in the hose it may be blocked with debris
Posted on Dec 05, 2014
Can low water pressure cause my toilet cisterns to keep running
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
Nov 16, 2016 | Home
The water no longer gets cold . What do I check ? Thanks !!
On a washing machine?
You have a hot fill inlet, you have a cold fill inlet. The controller dictates how much hot water and cold water to get the right temperature for the wash you have chosen. This is tested by the thermostat in base of the drum. The heater then warms the water to the correct temperature for the full wash.
Some washers are cold fill only and the heater in the washing machine does all the work. The wash cycles take a lot longer.
If you are in fact talking about a water cooler not getting cold, check the air filters and for dust on the compressor fins.
Jan 13, 2016 | Washing Machines
Washer will not fill with water
i know this is a silly questian but has it got a supply ie,double check that water is present and switched on.adrianxxx
Feb 25, 2012 | Kenmore 44072 Front Load Washer
My washer no longer produces cold water, only hot, except for the start of the cycle. The machine will tell me that it's not getting cold water. It doesn't matter whether I set the water temperature at...
It sounds like the fill hoses are inverted. Most of the Fisher washers only fill with cold water after the initial fill. So if the hose are inverted then it will only fill with hot. Beyond this I'm at a loss. Good luck
Apr 23, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Asko W6021 won't fill. It clicks and starts, but no water fills drum. I've cleaned drain trap but don't know how to clean inlet filter as suggested in manual.
The water inlet filters are inside where the hot and cold water supply hoses screw into the machine. Turn the water off, unscrew the hoses and they should be visible. However it might not be those causing the machine not to fill. If they needed cleaning the water would fill- but taking longer each wash.
If you confirm the filters are clear, it is more likely to be symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, or the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 20, 2011 | Asko W6021 Front Load Washer
Maytag washer will not fill with water. It does agitate and spin
My May Tag model LA 882 washing machine is not draining water. the water remains even after spining and the cycles are longer durations. any advise ?
Mar 31, 2009 | Maytag Washing Machines
The washer is very slow to fill up with water.
cut the water off to the fill hoses,,than remove fill hose and clean water inlet vavle screens with tooth brush..onthejob
Jan 18, 2009 | Maytag PAV2300 Top Load Washer
Washer fills with water when not in use
you have a faulty water valve asm which needs to be replaced. cut off water supply to prevent flooding
Dec 16, 2008 | LG WM2277H Front Load Washer
Wash cycles are increasing in time required to complete
cold water valve in back could be plugged causing longer fill times.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
