Question about Toshiba Computers & Internet
Enable the microphone on a toshiba equium
Not sure how to go about it
You need to get a mic / headset
ive even found them in the £1 shop
and they work aok
on the front of the equium is wo sockets and a small volume rotory control
place the green plug into he headphone socket
and the other plug into the mic input socket
the equium doesnt have a built in mic
so you need to do this
once this is done you can open the volume control {task bar} or the realtek applet in the control panel
or .. just the windows sound applet
fine the mic input section and check its not muted
you can use skype echo test to make the levels good and test it out
windows all also allow you too do this
my advice with the equium and XP is too go to the realtek site and download the AC97 driver from there
it works better
ive retired my equium now but it still works fine and i enjoyed writing over 2GB of code and projects on it ..
good old equium
Posted on Dec 05, 2014
Need manual for toshiba 3387db
Log on to here for the pdf User's Manual. Don't forget to disable any popup blockers your browser may have to enable download.
http://www.manuals365.com/download/toshiba/293387db.html
Aug 02, 2015 | Amstron Toshiba Equium A100-338 Laptop...
I have a toshiba equium tryin to set up microphone but no matter which option i use it wont recognize my voice
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 23, 2011 | Toshiba (P000257700) Microphone
Equium 100 PC Desktop: my sscreen has rotated on my Toshiba EQUIUM A100-0...
hold ctrl+alt and press the up or down key to change the screen to its original position
May 05, 2010 | Toshiba Equium 100 PC Desktop
How to enable the microphone on Toshiba equium p200d 139 for use with Skype
Hi there!
Just follow the link (video) below for all information:
http://www.youtube.com/watch?v=sodMDs7rEEk
Please rate this solution if you found it helpful.Thanks!
Feb 27, 2010 | Computers & Internet
Toshiba Equium 2000 does not recognise USB keyboard
check bios settings and enable kboard usb settings is ok, save to cmos and reboot
Feb 18, 2010 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
Touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Sep 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
    Upgrade the processor on a Toshiba equium l40 series from a celron M
    The core2 duo chips will be a different socket to your celeron cpu so can do that unfortunately. You may be able to upgrade to a faster cpu of the same socket type but will probably need a bios update for it to run at proper speed.
    Unfortunately laptops arent really designed to be upgraded at all bar extra ram/hd/dvdrw.
    Hope that helps?
    Dec 26, 2007 | Toshiba Celeron, 2.50 GHz (P000396980)...
    Microphone is not working
    You need to check that all of your sound devices are enabled. Most laptops will shut down certain devices when on battery to conserve power.
    There are setting available to alter the microphone gain in the sound settings part of the control panel. Under Sounds and Audio Devices Properties. Check the sound recording section under audio, make sure the microphone is enabled and that the volume slider is not at minimum. Under XP there is a test hardware button that should help.
    Dec 13, 2007 | Toshiba Satellite A135-S2276 Notebook
    Open Questions:
    Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
    Jul 05, 2018 | Toshiba Computers & Internet
    Computers & Internet Logo
    56 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
