Lj 3055 printer usb not detect - Office Equipment & Supplies
Try a new cable
try it on another pc
if the doesnt work i think perhaps the usb controller on the printer may have an issue
if it turns out your pc has an issue
try another socket
if this isnt right you need to check your pc usb system
in the device manager for any yellow ! drivers not working
you can always add a pci card for usb2 etc if it turns out your pc port is faulty
Posted on Dec 05, 2014
HOW TO CONFIGURE LASERJET 3055
USB: Run the cd, when its asked for connecting connect the usb cable, do rest..Network. Menu>network setup>TCP/IP>enter IP address>save it.connect network patch cable, take configuration page through printer menu settings, verify the IP address save or not> go to system 1. Run the CD select network as network printer> system will detect the printer go for rest of the process..
2. Through system> start> settings>printers& faxes>add printer wizard > select as local printer> select create new port in dialog box> select TCP/IP> type configured IPadress> do rest of the run process..
Jul 11, 2012 | HP LaserJet 3055 All-In-One Printer
Ip not save in hp lj 3055 aio
Please describe the problem in detail. IP is never saved in any printer.
Dec 22, 2010 | HP LaserJet 3055 All-In-One Printer
Memory low on my hp lj 3055 how do i resolve this?
Press cancel to clear the error. Break the job into smaller jobs.
You didn't document the complete message.
Oct 25, 2010 | HP LaserJet 3055 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Getting System PCL XL Error
I think u have installed the PCL 5 or PCL 6 driver.Not to worry
Go to www.hp.com and download the PS driver for LJ 3055. Install the driver,u will not get the PCL XL error any more.
Thanks
All the Best!!!!!!!!!!1
Jan 08, 2009 | HP LaserJet 3055 All-In-One Printer
Can't print to old applications
The issue your having is with the Operating system compatability. The HP 3055 is compatible with 98, ME, XP, Window 2000 and forward. It won't do windows 3.1 or 95 well even if your computer will, the disconnect comes when the software is sending old print commands to a new style print driver.
Your best hope is to download and install the HP Printdriver for Windows 98 and try it as it's the most tolerant of old gear. Download the PCL 5 as the PCL6 is too new and probably not going to work.
As an alternate try to download each of the printdrivers for the differnt era windows and try them. It's a hard problem that may not have a solution other than upgrading the accounting software.
If it's simply a connection problem, they do make a USB to Parallel addaptor which may help you with the physical connection issue.
Here's a link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=1140780&taskId=135&prodTypeId=18972&prodSeriesId=1161389&submit.y=4&submit.x=3&lang=en&cc=us
Hope that helps you.
Aug 24, 2008 | HP LaserJet 3055 All-In-One Printer
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
29 people viewed this question
jasbo
jasbo
