Just before the spin cycle, there are horrendous sounds of metal clanging like cogs in gears slipping. What is happening?
I have not tried to do anything. The metal clanging noise is frightenening
Either the drum bearings are gone {you need an engieer to do this and its a long and labourious job but extends the lifespan of the machine}
the pump motor has coins or other metal parts inside it {take out the filter and clean the whole pump even inside it look with a torch for any bits of metal} you may need to lay the machine down on the opposite side from the soap drawer
and take the hoze off the pump and check its traps
as some machines dont have a screw in filter tray
you could find there is wires from clothes inside the skin of the drum
perhaps the kids post to the soap drawer a toy car etc
this end up inbetween the drum and the drum outer skin
and will start to bang around when the drum moves to faster speeds
to clear this you need to fully empty the machine and then take the heating element out and fish around with long tweezers to grab the bits and pieces
something like this is the issue
i would let a service guy have a look
the bearings you can tell if you open the drum door and move the dum up and down left and right
if there is play in the inner drum then the bearings are gone
i bet its something inside that will float about when there is more water in the machine
Posted on Dec 05, 2014
Also, I forgot to add on my axxis+ washer, when it goes into a spin cycle, it sounds like change our something metal is clanging around in the drum. I've opened the door and felt inside but there is...
Yes it can and does happen. u have to remove the top or cabinet. then look at cabinet for marks or scrapes where something may be rubbing?
Mar 07, 2015 | Washing Machines
Why agitator not trning in kenmore washing machine?
If the spin cycle works, but the unit only fails to aggitate......the problem is most likely a clutch or transmission problem. If the unit neither spins or aggitates, you could have a broken belt or even a defective lid switch. Sometimes a model will have broken dogs, or cogs in the aggitator base. To check this, with the machine off..reach into the machine tub..grab the aggitaror and try to turn it manually by hand. If you can turn it and also feel a sensation such as a gear slipping or teeth not properly taking hold or meshing, the cogs or dogs may need to be replaced that are under the aggitator itself. Best Wishes
Sep 01, 2014 | Washing Machines
Whirpool duet model#WFW9300VU02Why doeswasher clangs and bangs in the spin cycle
the spider gear is broken,it would be cheaper to replace the washer than have it repaired,you either overloaded the washer or used to much detergent,you should only use two tablespoons of h.e. detergent in a front load washer or you did both,if you look at the back wall it looks like a peace sign,that's where the gear is
Jun 23, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Rock stuck in grinder. just spinning noise when it
It is not a healty sound,seems either the gear cogs slipped or the plastic base that holds the lower blade of the grinder is broken.
Jan 02, 2010 | Saeco Talea Giro Espresso Maker -...
My Dyson DC07 Makes a loud sound like a belt slipping over a cog. Sometimes it will go for days without doing it. Other times it will happen every minute or so. It
Once again check for blockages in the brush bar compartment.The brush bar should spin freely
The clutch may be slipping to protect its self when their is something stopping it from from turning
Aug 22, 2009 | Dyson DC07 Full Gear Bagless Upright...
Washing machine makes a clanging sound during agitation/spin
Without being there to physically see what it's doing or hear the sound, I would say there's 3 possibilities. 1) drive block is slipping on basket drive / brake assembly. 2) basket drive assembly is worn where drive block seats onto it. 3) clutch slipping.
Sep 26, 2017 | Whirlpool Washing Machines
HOOVER 510 PREMIER WASHING MACHINE ABOVE THE BELT SHAFT THERE IS A PLASTIC COG WHEN THE WASHING MACHINE IS ON WASH CYCLE IT SPINS FINE ONE WAY THEN ON THE REVERSE SPIN THER IS THIS ORANGE LEVER THAT MAKES...
I imagine you've bought a new machine by now? The plastic gearcog is the clutch housing. The arm that clicks is part of the brake lever. On these models, the brake lever is supposed to hold the clutch in place during the wash cycle so that it slips in both directions to get a forward and reverse wash. On spin, the lever moves away releasing the clutch and gearbox brake and allowing the bowl and agitator to spin together. The brake lever wears and allows the gearbox to slip during the wash cycle. When this happens, the clutch housing will "ratchet" past the brake lever tongue. this causes the "clicking" noise in 1 direction.
Oct 17, 2008 | Hoover Washing Machines
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Jul 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
Top Washing Machines Experts
