Question about Trendnet TEW-731BR 300 Mbps Wireless-N Home Router - 300 Mbps, Wireles
Why my router trendnet tew-731BR doesn't working?
I bought a new trendnet tew-731br router today, and it doesn't work. Only the Power and the Status lights are on, the other lights doesn't work. What could be the problem?
  • 711 Answers
You have to look on the tag at the base or back and find the IP address and admin / password sign in to set it up. Set of numbers like 192.168.0.1 or www.routerlogin.net then when on the routers server you can enter your ISP details to get the router setup.
Posted on Dec 05, 2014
Firmware checksum error TRENDNET
Wrong or corrupt file. Try downloading the firmware file again.
Feb 15, 2015 | Trendnet Computers & Internet
How do I secure my wifi
You need to download the user guide to get the full instructions from here. The quick guide and datasheet are no good.
TRENDnet Support
Briefly
1. Log into your router management page.
2. Click on Wireless, and click on Security.
3. Click on the Authentication Type drop-down list to select your wireless security type.
you have a choice of WEP,WPA, WPA-Auto, or WPA2 . WPA2 being the most secure. The user guide gives full details of each setup.
Jan 20, 2015 | Trendnet TEW-731BR 300Mbps Wireless N Home...
Setting up router
There is a good page at the link I'll show below that tells about default addresses and login names/passwords for Trendnet routers. Although 192.168.10.1 is -common- with Trendnet, so is 192.168.1.1 - and if both of those fail, find the little reset button near where your LAN/Internet source line plugs in, with a small object (unfolded paper clip will do) press and hold the recessed reset button for several seconds, then power it up as normal. This resets the router back to factory defaults.
router defaults com
Jan 30, 2014 | Trendnet TEW-731BR Wireless Router - IEEE...
Lock wifi so anyone that wants to use it needs a password
go to wireless network properties and set the network authentication to shared key. then supply the network key you like. email me so i can help you if cant find it. jasonperez_1@msn.com. i am more than willing to help you
Jun 24, 2012 | Trendnet TEW Computers & Internet
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
Oct 14, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How I can reset the password? I do not remember it
You must remove all power from router, and press the reset button, this will return the unit to factory spec's then you can login, as default, and re-setup the router.
downloads.trendnet.ru/TEW-231BRP/Manual/QIG_TEW-231BRP_EN.pdf
http://www.trendnet.com/downloads/list_subcategory.asp?SUBTYPE_ID=869&SUBMIT=Go
All in these manuals above..
Apr 09, 2010 | Trendware TEW-231BRP Wireless Router...
How to change password for Trendnet TEW 432BRD wireless router
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
CLick on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
My tew431brp status led is permanently red, it won´t work, it´s not possible to go to the config menu again, the old configuration previously stored doesn´t work either
When in doubt flash it! Though you must reset it to default protocols first. There should be a reset button somewhere on the unit, press and hold for at least 15-30 sec. If this does'nt work you may have been zapped by some stray volts and in this instance is not cheaper to keep her.
Jul 02, 2009 | Trendware TRENDnet TEW-431BRP Wireless...
TRENDnet TEW-432BRP router cannot obtain IP through DHCP
it seems that ur PC & cable modem configuration is ok, now the problem is with ur router WAN interface configuration. the problem would be one out of 2 - first to check whether ur router wan interface is configured properly to obtain IP address from DHCP (if possible, u can give the static ip address with same series as cable modem) second to check with ur ISP.
Mar 19, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Trendnet TEW-731BR 300 Mbps Wireless-N Home Router - 300 Mbps, Wireles Logo
124 people viewed this question
Top Trendnet Computers & Internet Experts
Lynne
Are you a Trendnet Computer and Internet Expert? Answer questions, earn points and help others
