Furnace started making a horrible racket from side inside trailer behind exhaust grate under fridge and ran like that for bout 2 weeks/ now it stopped working.
Removed thermostat cover.Esablished that Ac & fan still kick on & that thermostat does click when temp is tripped
    Master:
  • 602 Answers
Squirrel cage blower wheel is loose on the motor shaft
Posted on Dec 21, 2014
  • 113 Answers
SOURCE: codencer on out side unit tries 2 run but kicks off every few sec
check you capicitor
Posted on May 02, 2009
shastalaker7
  • 1515 Answers
SOURCE: Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Posted on Nov 04, 2009
hvac1
  • 338 Answers
SOURCE: Fan runs but no cool air
Have you cleaned the unit? The condenser coil? The filter? The evapartor coil? Sounds like an airflow problem. You need to clean these areas. You can clean the condensor coil with water hose and a coil brush you can get at the hardware store. Clean the evaparator with the same brush. YOU can use a hairbrush if you don't have anything else. But make sure you go up and down on the fins on the coils not sideways. You might check your blower fan for dirt also. Good luck I hope I helped you. Could also be low on charge but first try cleaning.
Posted on Jun 30, 2010
  • 3074 Answers
SOURCE: Had water coming in through
sounds like a fuse was blown with the water problem, this should be in the unit on a main power board. Like 3 amp or so as it is low voltage.
Posted on Aug 10, 2010
  • 1033 Answers
SOURCE: ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Posted on Nov 26, 2012
Where is furnace located?
go to outside of unit look for 2 exhaust ports together that is the vent exactly inside is the furnace either inside a cabinet or behind a panel with screws
Nov 09, 2015 | Forest River 2008 Cherokee Lite 295B
I have a 2001 Pontiac grand am gt v6, the car was working fine, then one day it stopped and would not restart, but when it was put on the trailer it started and ran fine for about 2 weeks. Then it ha
check inside distributer cap for wear-clean or replace---inspect plug wires for conductivity-----test coil/ignition module-----------make sure fuel pump/regulator/injectors are holding pressure--------listen for vacuum leaks-------inspect whole car------do a scan at an independent shop not a partsplace
Nov 10, 2014 | 2001 Pontiac Grand Am
How hard is it to change the refrig side fan motor? Its making a racket! noise stops when door is open, fan shuts off The motor is inside behind a couple of panels. samsung RS265LABP
Sears parts department has a huge library of breakdowns of many appliances from all major brands. I ran your model number and it is included. The line drawings allow one to fairly accurately judge the location and access to internal parts:
Your Samsung
You should be able to replace your fan using the illustrations and in many cases, the correct part can be ordered from those pages.
Sep 06, 2011 | Samsung RS265LABP Side by Side...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No cool no start
auto defrost might be on. turn the dial until the compressor clicks on. it's usually located under the fridge behind the front grate.
Aug 06, 2009 | Amana ASD2622HRQ Side by Side Refrigerator
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Sub zero making a horrible noise
if it is coming from under your unit is it most likely the water inlet valve for the icemaker check that and let me know you will have to remve the 2 screw on the kick plate to get to it,it should be on the left side
Apr 07, 2008 | Refrigerators
Fish smell in the refrigerator
GRAB YOUR CHILDREN AND RUN FOR YOUR LIFE!!! THERE'S NO STOPPING IT!!!
Mar 25, 2008 | Hotpoint HSS25GFP Side by Side...
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
