Question about Braun Health & Beauty
Fixing trimmer on braun 9585
Spring machanism came loose
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
Why does my shaver turn off automatically when I turrn it on?
Replace the razor head making sure it sits secure so it won't block the cover and let it spin freely.
Oct 21, 2013 | Braun Series 7 9585 Hair Trimmer
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
I have a Braun 760 razor. The two electric contacts on the charging/cleaning base no longer make good contact with the razor. One of them seems to have some corrosion on it and prevents the razor from...
Useaa good emery paper to clean the surface of the contact, use a good contact oil to rub off the rust or dirt in the section. now repeat till it shine, do the same to the other end , Now since there is alwyas some moisture present the pins must be cleaned out after very use.
Sep 28, 2010 | Braun Series 7 9585 Hair Trimmer
Repair / replace trimmer on braun 9585 shaver
This part is only available from a Braun repair center. You can call a repair center at 847-869-7755
Sep 03, 2010 | Braun Series 7 9585 Hair Trimmer
The thin plastic internal piece that is needed to open and close the trimmer of my Braun #9585 has broken. Where can I get a replacement.
The trimmer is broken. This is a common problem with this model and only an authorized Braun repair center can help you with this. There is one in Evanston, IL that can accept shavers from all over the US. Their phone number is 847-869-7755
Aug 18, 2010 | Braun Health & Beauty
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
The pop-up long hair trimmer on my pulsonic razor 9585 will not stay closed
seems like the hinges have gone loose. do you notice an broken laches?
Sep 23, 2008 | Computers & Internet
Health & Beauty Logo
48 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
