Question about Dell 17" e177fpf lcd monitor black
In a dell e177fpf lcd monitor all the capasitors fuses diodes in power supply and inverter board are ok.but the back lights remains 2 seconds.
I checked all the components by an analog multy tester besides ic s and pcb mounted components.does tcon board give any continuos signal to backlights.And what are the common connection points between tcon board and power supply board,between inverter board and power supply board.exam;A dim B dim
    Problem Solver:
Hello...I recently opened up my Dell E173Fpf monitor because the screen went black, yet the power button was green. I thought it was a capacitor problem. But before doing anything I gave the board a thorough inspection, looking for anomalies. I observed a substance, (later identified as silicon) puddled around the power connections. I gently removed the semi rigid stuff and didn't touch the capacitors as I had originally planned. I partially reassembled the monitor for a test run and it worked again. (Being 9 years old, I don't know for how long...) Only thing I can think of is that a spill happened at the factory and over the years it gradually "melted" to puddle around the wires behind the power input. (Weird, but that seems to be what happened.)
Posted on Dec 05, 2014
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
The unit will not show a picture. the power lamp flashes and all buttons are unresponsive, including the power button... I have unplugged all cables, including the power cable, then allowed the unit to...
You may have dying power supply problem due to bad DC filter caps, which is is very common problem in ALL LCD monitors. You need to open it up and do some in-depth troubleshooting.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 09, 2011 | Samsung SyncMaster 2220WM 22" LCD Monitor
My Dell E153FPc 15" shuts
Look for cold solder joints, shorted transistors, bad fuse, bad caps.
See pictures here: http://s807.photobucket.com/albums/yy352/budm/Dell%20E153FPB/
Replacement board: http://www.lcdrepair.us
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Feb 02, 2011 | Dell E153FPc 15" TFT LCD Flat Panel...
Have a dell e177fp monitor. When I power on it only displays for 3 seconds and shuts off. Green power light remains on.
You need to check the voltages and components in the power supply/inverter board first. It should have 5vdc for logic and 12~16vdc for the backlight innerter circuits.
There are three version of the boards for this model.
http://lcdrepair.us/Invpowersupply.html
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jul 08, 2010 | Dell E177FP LCD Monitor
About a week ago my Dell 2007WFPb LCD monitor (purchased in 2007) flickered on and off PIP mode, and would not stay on one setting for PIP for longer than 2 seconds. It was not fixed and now the power...
Not the power cord problem at this point, more likely to have failed Power supply or Inverter board.
http://lcdrepair.us/2007fpw-power.html
http://lcdrepair.us/2007fp-inverter.html
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Jun 15, 2010 | Dell 2007WFPB LCD Monitor
My dell monitor turns on for 2 seconds then goes black and the green light blinks orange
I assume that you already try this monitor on another PC to verify that the problem is in the monitor, in this case you need to open it up and inspect the fuse, transitors, solder connections on the power/inverter board, see failed Dell monitors here for guide: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 23, 2010 | Dell E173FP 17" LCD Monitor
Monitor goes black but the green light stays on. I turn the power button off and then back on and it comes back on. It may stay on for a few seconds to several minutes.
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the back lights are not being powered. There is a signal going to your FPD because the power light remains on green, but the back lights are what helps support an image from the Front Panel Display.
The only way to fix this is to open it up.
If its got 3 boards inside((logic-->video, Inverter, Power)) The problem is the Inverter. Replace it.
The inverter is the board that supplies power for the backlights to turn on. The backlights
provide a light.for the LCD Panel(provides color and is the logic. ... similar to a projector.
If its got 2 boards inside ((Logic-->video, Power)) The problem is the power supply. The inverter is embedded onto it.
Simply replace the part with a known good one, and you got a spanking new monitor.
Sep 18, 2008 | Computers & Internet
Dell 1701FP monitor - power buttons blinking - no display - no white screen
hi my name is joel joely from etech vanuatu limited. my dell LCD monitor is just blinking power light on with orange light and also power switch not working if turn it on or off no display on screen.
my email address is joel@etech.com.vu
thanks
joel
Sep 06, 2007 | Dell UltraSharp 1701FP 17" LCD Monitor
Dell 17" e177fpf lcd monitor black Logo
117 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
