Question about La Pavoni Coffee Makers & Espresso Machines
Hi what size tamper do i need for la pavoni ebr machine about 12 yrs old thanks
What size tamper do i need for this machine thanks helen
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
Hi I have one of these in the attic, they do not come with a tamper as they have a fancy pressurised portafilter , its good to level the coffee and if I remember I did used to give it a bit of a tamp as it just didn't seem right not to. I have found a couple of references to tamper size on the web and both say 53mm I can't totally vouch for this though, you can always check with a ruler.
Posted on Dec 16, 2014
  • Piers Carter
    Piers Carter Dec 16, 2014
SOURCE: no pressure
The relief valve has a toggle inside that is heat activated. This can stick. I found if you tap it with a spoon the toggle will release and the valve will close.
Posted on Sep 29, 2007
SOURCE: lA PAVONI PISA
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Posted on Mar 28, 2008
mirran
  • 515 Answers
SOURCE: service a pavoni hand espresso machine
Look at this site an see if you can find a place to repair it.
http://www.lapavoni.com/
Posted on Jul 15, 2008
LaPavoniBoy
  • 36 Answers
SOURCE: Leaking water from the group and steam spout
You will need to take the machine apart completely as there are more gaskets inside the group head. You can buy an old group service kit at www.theespressoshop.co.uk for about £20 and it comes with an exploded diagram so you can see what goes where. Don't worry there is no technical mechanical solenoid like the last comment stated. I repair these machines for a living and all it needs is a good service.
All the best
LaPavoniBoy
Posted on May 28, 2009
  • 3 Answers
SOURCE: I need to see a picture or the wiring diagram for
I also will email you the pdf attached file in case I can't upload the pictures here.
I wire diagram I am adding is from a lelit but they are the same if some pictures I took from my nap. did not come out so good for you email me and I will send the original file.
Hope this will help you good luck
Hm well the file size is to small for a upload here if someone else needs it just email or send link for upload.
Tata
Posted on Jan 16, 2011
I'm looking the right part (portafilter or handle and cups) for my La Pavoni Duet PA-1315.
try this link
if not listed use contact us or ask
some parts may have been discontinued
La Pavoni Parts
Oct 11, 2016 | La Pavoni Coffee Makers & Espresso...
Tip
La Pavoni Lever Machine Hissing?
If you have a La Pavoni lever model espresso machine and the safety assembley on the top right hisses while the machine is heating up, all you have to do is use something hard but preferably not metal or too large and tap the safety assembly quite firmly but not to hard and this should stop the hissing. This is because inside the assembly there is a bung on a spring and sometimes it becomes stuck and just needs a gentle tap to free it up. If it doesn't stop hissing then you can remove and stretch the spring or if needs be replace the spring and bung.
All the best
Mr La Pavoni
on Jun 02, 2010 | La Pavoni Europiccola EPC-8 Espresso...
I need the order for the 3 wires on each 0f the 3 swithes ? on a epl 12 !!
Hi this link goes to a site that covers quite a lot of stuff about Pavoni lever machines hope you find what you need. I have set the link to land on a page that has a wiring diagram,
Powering up the La Pavoni
Aug 06, 2014 | La Pavoni Coffee Makers & Espresso...
Fuse keeps blowing La Pavoni Europiccola 1996
Hi That's a short it's all it could be isn't it. Plug? lead? water or damp in the base? try slipping the black base off you will need a security bit to get it off or at least mine does its a t bit with a hole in the middle I think, have a look for water that might be shorting it out also try it in another socket , you never know.
Best of luck.
Feb 28, 2014 | La Pavoni Coffee Makers & Espresso...
Hi can you tell me how to reset the safety thermostat on a La Pavoni EBR. The instruction manual tells you to do this but does not show you where it is or how to do it! Rob Burd
Hi Rob,
Open the top of the machine. On the heater element you'll see 8 cable connection: 2 on one end, 3 pairs on the other. The safety reset thermostat is on the middle of the 3 pairs (easy to spot the other 2 is flat, the middle one has a 2mm part sticking out). Remove that pair of cables - just in case - and push that button in. You'll hear a clicking noise. Connect the two cables back to the element and follow the "starting up procedure" from your manual. If you did everything correctly the machine will start to operate. Turn it off and put back the top. That should be it.
Dec 09, 2010 | La Pavoni Lusso PL-16 Espresso Machine
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
All the best
LaPavoniBoy
Nov 13, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni Professional, Chrome, 16 cup capacity Europiccola
You have to take a screwdriver and try to bend up the platic, be careful so you not break it.
Aug 20, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
No pressure
I have the same problem are awaiting reply from la Pavoni direct...I suspect there is a fualt with the pressure gauge as it is steaming up too!!
Jun 10, 2007 | La Pavoni PC-16 Espresso Machine
Coffee Makers & Espresso Machines Logo
81 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
