Question about Dehumidifiers
My dehumidifier is very noisy, why is this?
Nothing
  • 2,760 Answers
Ck cooling fan on inside of cover (unplug first) see if it's got a build up of dust and stuff on it , that sets it out of balance and makes whole unit give off noise , clean off with windex or simmiliar product , set unit flat on floor and run it
Posted on Dec 09, 2014
Is a gold star dehumidifier supose to be noise
I can't hear YOUR dehumidifier and can't tell if it's out of the ordinary, but dehumidifiers have all the same internal parts as a refrigerator with the addition of a fan to blow air through the coils to keep them from freezing up. They do tend to be a bit noisy.
Feb 22, 2015 | Goldstar Dehumidifiers
Noisy when opporating
depends on what is cause of noise, if a fan, something in it, or could be a bearing worn
Aug 08, 2014 | Winix 50 Pint Dehumidifier WDH851
Santa fe advanced dehumidifier is very noisy. Can you help me to quiet it down please?
Call the factory at 1-800-533-7533 for help troubleshooting your noise.
Jun 09, 2014 | Santa Fe Dehumidifiers
I have a comfortaire bhd501-d that is very noisy. Any solutions? I checked the screws on compressor and they are tight.
Pull the plug on the unit and strike it moderately with your hand listening for any vibrations. Try to pinpoint the source of that vibration and correct it. You should also place the unit on solid ground to eliminate the possibility of the noise being amplified by the surface it is sitting on. "Very noisy" is very subjective. Best I can do for now. Please post your findings
Jun 06, 2014 | LG LHD45EL Dehumidifier
Vibration Noise Fix
Place the dehumidifier feet on foam or rubber vibration absorbing pads.
Touch all sides of the cabinet with the compressor running to see if your touch will dampen the noise. Once the noisy area is identified check that the fasteners are all in place and tight. Sometimes loostening and retightening a number of fasterners around the noisy area will cure this problem.
Apr 30, 2014 | Honeywell DR90A1000 TrueDRY Dehumidifier...
Crosley conservator dehumidifier will not capture humidity
Have you noticed it not running as often or not being noisy? Also have you tried to select a continuous drain setting if your unit has one?
Aug 14, 2012 | Crosley W.C. Woods DCW40S Electric...
My Haier dehumidifier is really noisy. If we turn it off and restart it, it will run quietly for maybe 4 minutes and then start getting really noisy again. Any ideas what is causing it and what I can do...
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 14, 2010 | Haier Dehumidifiers
I HAVE 4 EA NEW LHD659EBK DEHUMIDIFIER and they make lots of noise and vibrate a bit, this is normal in these Dehumidifiers ..
These can be noisy.
Does the noise only happen when the compressor runs? These compressors float on rubber bushings to isolate the vibrations and maybe one of the three nuts on the mounting studs may be loose.
The fan bearings can also wear out.
Nov 21, 2009 | LG LHD45EL Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
