When I pressed input the cursor when to source and the tv went blank. How do I come off
    New Friend:
  • 23 Answers
Keep pressing Source until you see its,not blank
Posted on Dec 05, 2014
I accidentally hit a button on my remote - I'm not sure which one - and my tv screen went blank.
You hit the OFF button Lori? lol
No, you probably hit the Input or Source button. Press it again until the picture comes back.
Feb 06, 2016 | Televison & Video
You have to turn up the volume to 38+ in order to hear the TV, when you use to be able to hear it at 10, is there a control board that goes out and what Is the name of it?
Hi Geoff, I hope I can help you with this. If you are using an accessory device (DVD, DVR) check cables to see that they are secure and if device has audio out option that it is set correctly. Also check to see that Video and Audio cables are connected to matching inputs on your set.
If you are using DVI to HDMI you will need to use a separate digital audio cable. DVI cables do not carry audio signal. After attaching the audio cable if you still do not hear sound you may need to set Digital Audio In. To do so:
  1. Press Menu Button on remote.
  2. Press the cursor ring down to highlight SETUP.
  3. Press the cursor ring left to enter SETUP menu.
  4. Press the cursor ring down to highlight SOURCE.
  5. Press the cursor ring left to enter SOURCE menu.
  6. Press the cursor ring down to highlight DIGITAL AUDIO IN.
  7. Press the cursor ring down to select the source you want to associate Digital Audio with. HDMI 1 or HDMI 2 in this case. You might need a software update also.
    The latest software solves the issues below:
    1. TV (Plasma 42" and 50") will not turn ON/shut off itself and Red LED blinks 4- times. Recover if main switch on/off.
    2. 37" LCD full white screen appear when upgrade software.
    3. Some channels not available after turn ON.
    4. Delta volume changes, not remembered.
    5. Preferred channel changes, not remembered.
    6. Green or yellow static (sometime snowy) on HDMI picture.
    7. Picture and sound loss for 5 to 10 sec (green LED is still ON) and back to normal.
    8. Audio loss in all inputs and can be recovered when main switch ON and OFF.
    9. TV set turn ON by itself/ green LED light up and goes off when set is ON.
    10. Intermittent audio loss in NTSC RF channel.
    11. Crack sound with high input signal.
    12. Include the possibility to download the rating table (RRT5 capability) for digital programs.
    13. No video/ no picture with sound.
    14. Intermittent On-Screen Menu pop up by itself and can be removed by pressing the 'MENU' button.
    15. Channel information display too long.
    16. Improvement on scramble channel.
    How to check the current software version on my TV set?
    1. Press 'MENU' button on remote control to display the on-screen menu.
    2. Select TV MENU and press the cursor right.
    3. Select INSTALLATION and press the cursor right.
    4. Select SOFTWARE UPGRADE and press cursor right.
    5. Select CURRENT SOFTWARE INFO to display the current software version on your TV set.
    6. If the TV software version is lower than the version posted on the website means your TV set needs to be upgraded.
    7. Follow the instruction in the user manual or Firmware Upgrade Readme file on how to upgrade your software.
    Where can I find the latest software for my TV set?
    The Firmware Upgrade Software and Readme File documents can be found on the Philips support website. Refer to the SOFTWARE section.
Feb 04, 2016 | Televison & Video
How do I use the video source button? I can see the different video inputs I can select on the screen after hitting the button but I can't move the cursor to select a different video source an
On Most TVs I have messed with, Hit the input or source button muliple times to cycle throught the different inputs. Also make sure there is an active device on the input for the TV to recognize it. Good luck
Jan 03, 2015 | Televison & Video
Not detecting devices
test this steps and fix it. God bless you
    • 1
      Check the back of your Sharp TV for the HDMI input. These will be long, thin rectangular jacks labeled "HDMI." Most Sharp TVs will include another label on those jacks with an input number ("Input 5," "Input 6" or the like). Remember that number. It will have a bearing when you turn on the TV.
    • 2
      Connect one end of an HDMI cable to the input jack on the Sharp TV and the other end to a compatible component such as an HD DVR from your cable/satellite company or a Blu-Ray disc player. The TV won't broadcast in HD if you can't connect these devices with an HDMI cable (though it will still broadcast in standard definition using RCA cables or S-video cables).
    • Sponsored Links
    • 3
      Turn on the TV and the requisite component (Blu-Ray, DVR).
    • 4
      Press the "Input" button on your remote. A list of signal sources will appear on your screen ("Input 1," Input 2," etc.). Use the cursor to maneuver down to the input number corresponding to the HDMI outlet you just hooked up and press the "Input" button again.
    • 5
      Press the "Menu" button and maneuver the cursor to select "Option." Go to "HDMI Setup" and press "Enter." Move the cursor up or down to the desired item and hit "Enter" again. Then move the cursor from side-to-side to select the proper setting. Hit "Enable" to allow the Sharp TV to automatically recognize the HDMI signal and "Digital" to get the proper audio signal from the HDMI cable. Then hit "Enter" again.
    • 6
      Exit the menu and watch TV as normal.
Read more: http://www.ehow.com/how_4840499_turn-hdmi-input-sharp-tv.html#ixzz2a6Xat0JU
Jul 25, 2013 | Seagate 1TB GoFlex Cinema Multimedia Drive...
Im having problems with my brand new Westinghouse LD4255VX. i bought it tonight, took it home and took it out of the box. at first it turned on fine, then got to about the 3rd step in the setup menu and...
It sounds like the problem is simply the input selection.
SELECTING THE INPUT SOURCE
There are two ways to select the video input source.
Using the Individual Input Keys
TV, PC, Video, YPbPr, HDMI Keys
Press any of the following remote control keys to change the input source: TV, PC, Video1, YPbPr1, HDMI1, or HDMI2.
Let me know if this fixes your problem
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | Televison & Video
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
Apr 28, 2010 | JVC LT-42E478 42 in. LCD Television
When i connect the cable from my computer to my tv, i am not able to use the laptop and there is nothing appearing on the tv screen
Check the manual for your laptop. Most laptops have a blue function key that must be pressed in combination with another key to activate the external video port. Usually you can choose laptop screen, external monitor or both.
Some television monitors will automatically change sources if there is no signal on one of the inputs. If you computer went into a blank screen saver mode, the TV may have switched to another input source.
Oct 10, 2009 | AOC A20S431 Television
Cannot connect acer laptop with samsung lcd tv
Dear Sir,
Welcome to Fixya
Solution:
Generally in all lcd tv you have to select input source in TV menu settings,if TV taking input from AGP,you have to select input as AGP ,if it is composite,select source as composit,if it is RGB select RGB as input by using your TV remote.Then press Fn+F5 in your laptop.
I think it helps.
if you have any problem regarding this issue leave a comment or feedback we were happy to assist you.
Have a Nice Day!
Oct 03, 2009 | Samsung Televison & Video
BLANK TV
hi, what you need to do is find the source button or av button on your remote control as it sounds like its changed source this causing your problem. As you probably know your telly has many inputs for dvd vcr cable or sky but these plug into one of the inputs in the back of telly. Usually the problem is just that your on the wrong input channel like av1 instead of av2 or rgb their are many inputs so you might need to press this button 2 or 3 times till you get the right channel, i dont mean 1 to 9 channels i mean input channel like rf input or av input. This depends on what your getting the signal from if its cable and its plugged in via scart lead then it will be an av input but you might have av1 av2 av3 av4 this depends on your telly.
If your still having problems then give me a shout back ok best to check all the leads are in the telly correct as this will cause the problem your having ok.
Let me know how you get on ok or if you need further help
May 14, 2008 | Philips 32PFL5322D Television
Model 60PL9200D/37 no sound
What device is connected to TV: cable, sat box, dvd player? What type of cable are you using to connect to the accessory device?
For a red, white, and yellow cable:
I cannot hear sound from the television when connecting to the AV1 input. What do I need to do?
Answer When you connect the accessory device to the AV1 input of the TV using either component video cables (YPbPr) or composite video cable (Yellow), you must connect the audio output from the accessory device to the 'INPUT AV1 AUDIO L R' of the TV using the RCA audio cables (Red and White).
If the connection is good,
Check to ensure that the AV1 audio source from the TV on-screen menu is selected to AV1.
  1. Press the 'MENU' button on the remote control.
  2. Press the cursor up/down to select SETUP and press the cursor right.
  3. Press the cursor up/down to select SOURCE and press the cursor right.
  4. Press the cursor up/down to select ANALOG AUDIO IN and press the cursor right.
  5. Press the cursor up/down to select AV1 and press the 'OK' button.
  6. Press the 'MENU' button to exit the menu.
Make sure that the volume on the TV and on the device is set at an audible level and also that the sound hasn't been muted.
For HDMI,
The picture quality is good but the TV does not produce any sound when connected to an accessory device with an HDMI to HDMI cable.
Answer
  • The TV's behavior is considered to be normal as some accessory devices have an HDMI audio output setting that requires to be turned on when using an HDMI to HDMI connection.
  • Check the on-screen menu of the accessory device to ensure that the HDMI audio output is set to ON.
  • In some cases, you may need to set the digital out audio stream of the accessory device to PCM.
  • For detailed information, please refer to the user manual of the accessory device.
Apr 07, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
