Question about Fisher and Paykel Washing Machines
Fisher and Paykel top loader washing machine, won't stop filling up with cold water
When filling with cold water, the water fill is not shutting off when it gets to the water level that I have the wash setting on, so water is then pumped out of the machine
  • 682 Answers
The pressure switch usually has air in the feed pipe which sometimes gets water into it which then fails to notify the system when to switch off water supply which then prevents the relay to the motor to start.check the feed pipe so it is empty of any water.this will allow the pressure switch to work properly.if the switch has failed you can get replacement part from eBay.
Posted on Dec 05, 2014
hattonhall
  • 349 Answers
SOURCE: fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Posted on Oct 19, 2009
jnchahn
  • 252 Answers
SOURCE: Water sensing level not working on Fisher &
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
Posted on May 07, 2011
  • 713 Answers
SOURCE: My fisher paykel top loader won't do a cold wash.
Hi just read your posting.Have you selected cold only?Are the hoses from the taps going to the correct water valve?Cold tap to c on the machine and hot tap to h on the machine.What is the model number of the machine?The model number sticker is on the back of the machine up top.Please reply with additional information and I am sure I can help rectify the fault.Looking forward to your reply/
Posted on May 21, 2011
richroth
  • 9472 Answers
SOURCE: my samsung top loader washing machine sw65v9w won't stop filling with water
If the water stops when you stop the cycle, then the pressure sensor is at fault. If you need to turn the water supply off to stop it, then the water inlet valve is at fault.
Posted on Nov 04, 2012
richroth
  • 9472 Answers
SOURCE: My Fisher and Paykel MW058 top loader wont fill up as fast as it use to
Turn off the water and remove the inlet hose at the machine. There is a filter screen there and it may be plugged up.
Posted on Nov 09, 2012
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel ecosmart washer won't fill or complete cycle
It can't get enough water so it flashers these lights
to tell you to turn your water on,
Your water valves are not fully opening to let enough water in.
You will need new water valves.
Oct 16, 2012 | Fisher Paykel EcoSmart GWL15
May 20, 2011 | Fisher and Paykel Washing Machines
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
Jun 14, 2009 | Fisher and Paykel (IWL12)
Water is not filling up.
turn off water
disconnect fill hose from tap
examine screen inside hose end for 'muck' blockage
clean screen
reconnect hose
test washer
if no fill
replace water solenoid valve
note: cold water valve fails first, it gets most use,
if only using cold water, you can simply swap the hot and cold hoses at the tap, and swap the hot and cold electrical connectors on the solenoid valves, the hot solenoid is no the cold one and the washer can be used, cold only, for about as long as it has operated thus far..
Oct 14, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
73 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
