Question about Car Audio & Video
I have a kenwood kac-7203 1000w 2 Chanel car amp n soon as I give it power it blows the fuse instantly what causes it to do that
  • Car Audio & ... Master
  • 5,651 Answers
There is a short circuit in the wires or in the unit! First check all wires it, could be any, you would need to check with a circuit tester!
Posted on Dec 05, 2014
2 Suggested Answers
  • 27 Answers
SOURCE: BLOWN FUSES IN AMP
maybe try the ground or make sure you dont touch metal to metal
Posted on Mar 30, 2009
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
I need to know the wattege of a kenwood kac -624
The KAC-624 is a 40 watt x2 @ 4 ohm RMS amp. 55 watt x2 @ 2ohm. 110 watt x 1 Bridged I assume at 4 ohm. Manual does not specify. It can run 2 ohm in stereo mode but is unclear on mono impedance requirement. It can run 4 ohm mono at 110 watt but at 2 ohm?
Dec 12, 2011 | Kenwood Car Audio & Video
I have a kenwood kac-728s and two coustic 10in. subwoofers hooked to it and every time i start my car and the radio powers on the two 20 watt fuses on the amp blows.any ideas?
That is pretty much saying that the amp's power supply is shorted or at least has a low resistance path to ground which is causing the fuses on the amp to blow. The amp has protection circuitry to prevent damage to the output stage so that is not what is causing this. Is the amp new?
Dec 30, 2009 | Kenwood KAC-728S Car Audio Amplifier
Kenwood KAC-729S keeps blowing fuses. Checked all cables, re-ran power, remote, and ground. All good, still blows them at power-up.
Hello opey_69a,
Here are the troubleshooting steps for fuses blowing.
1) Remove all wiring except ground, power and remote and see if the amp powers up without blowing the fuses. If it does, the problem is in the input cables or speaker wiring.
2) The use of loudspeaker impedances below the recommended minimums will cause the amp to draw excessive current - check.
3) A shorted or grounded RCA cable may cause the fuses to blow - check.
4) If an amplifier fuse blows continually, with only +12 volt, ground and remote leads connected, the amplifier is probably defective, most likely shorted output MOSFET's. In this case the amp needs professional repair or replacement.
Hope this helps.
Sep 19, 2009 | Kenwood KAC-729S Car Audio Amplifier
Kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Apr 16, 2009 | Kenwood KAC-X1R Car Audio Amplifier
Power amp wont power up
Check the fuses-should be a pair of 30 amps on the side. use a paper clip and jump power from the power+ to the remote+ and see if that lights it up-if it does than your remote lead isnt giving it juice-
Apr 06, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Running 2 amps
amps could be overheating or the subs could be requiring more power then the amps are giving off.
Apr 01, 2009 | Kenwood KAC-8452 Car Audio Amplifier
BLOWN FUSES IN AMP
Mar 24, 2009 | Kenwood Car Audio & Video
I have a kenwood kac-9152d amp i fried it opened it and the inner ground wire was fried in half now it just blows my fuses????
Dang! That's a class D anp! How did you fry it? If you "replaced" the internal ground wire and now it just blows fuses, I would say that the amp is direct shorted at the power supply if the fusesblow instantly when you put the fuses in.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Dec 26, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-X1R and one 12" Kenwood KFC-XW1222D at 1 ohm blow out.Why is that happening?
You may have a high resistance in your positive or negative power supply. with your amp you need to use at least a 2 gauge power cable. Is your fuse blowing? if so then a short circuit to ground may be causing that.
Good luck
Aug 01, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
