Question about Saws
How do I cut the the corners(miter) of Polystyrene cornice.
I tried cutting with a mitre box cant seem to get the corners perfectly
    Top Expert:
  • Saws Master
  • 34,089 Answers
Try making the cut with the rear of the cornice against the rear of the miter box rather than the front as you would for cutting regular (not crown) molding. I hope you are not using a circular saw to cut polystyrene.
Posted on Dec 05, 2014
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
Cornice mitre angle
Try this ... http://www.constructionknowledge.net/public_domain_documents/Div_6_Woods_Plastics/Partial%20Carpentry%20pdfs/Finishing_Roofs_NAVEDTRA_14044.pdf
Nov 25, 2013 | Makita 10" Dual Bevel Sliding Compound...
How do i cut floor trim with my stanley mitre box
To do the job right, you make a miter cut, then a coping cut. There is an excellent article on this at:
http://www.wikihow.com/Cut-a-Coped-Joint-in-Wood-Trim
Getting a nice-looking coped joint is very satisfying, but takes a bit of practice. But it's worth it. Miter joints are great for picture frames and trim on furniture, but not for trimming a room.
Oct 15, 2010 | Stanley Garden
How to build a wooden pyramid frame for school children, 2metres on each length of base.
cut 4 pieces of 2x2 to1.5 inches short of 2 metres. lay them out end to end to form a two metre box. it can only work one way. then take string from corner to corner to find the center, making a crosshair. then stand a level rod at the centre to the desired height and fasten equal length lines from each corner to the peak. using a compound mitre saw, place an angle finder at the bottom and top corners to give you the angle to cut your piece with the saw set at 45 degrees, to give you your compound miter for the top. just set the saw blade to line up with the angle finder to get the bottom cut. the length of your "tight" string line frome corner to peak is your length of "hip" piece
Mar 10, 2010 | RTO M-D Building Products Carpentry &...
Dewalt DW707 compound saw
Did you sense an odd smell? Try removing the brushes, there should be two, it could be one is worn too short or the connecting wire is broken.
Oct 30, 2009 | Dewalt DW703 10" Compound Miter Saw
What do i do to cut inside/outside corners for crown molding
It is very hard to make proper cuts with one of these.
You may want to buy a power miter saw.
You would be better off marking your 45 degree angle and cutting it freehand.
If you angle your saw a little the face will look like it matches up better.
If you need more help post a comment.
Tim
May 03, 2009 | Stanley Tools/Goldblatt Tool No.20 - 600...
My mitre saw wont lift up into the cutting position it seems stuk
look on the left side of the saw just past the blade there is a knob there pull it out as you hang onto the handle of the saw ,the knob is spring loaded,plus the if you dont hold onto the handle the unit will come up very fast.possible of hurting you or the saw.
Mar 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Saws Logo
85 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
