Question about Bosch Dryers
The heat stopped working on my Bosch WTL 5100 dryer (the dryer turns around just fine). I cleaned out the condenser filter, then opened up the back and pressed the red reset button. It worked -- once.
See above. I don't have a continuity tester, so I can't check the heating element that way.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 160 Answers
Are u getting the full 240 voltage in some machines it uses 2 settings to run and to heat? u might get 120 for running it but the other 120 to run heat> thus u get it running but no heat? other wise u may have a bad heating element or hi-lo thermostat or the thermal cut off fuse, u can check with multimeter and u can buy cheap multimeter at places like harbor freight for 5 bucks
Posted on Dec 09, 2014
  • 8 Answers
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
Posted on Dec 15, 2007
SOURCE: My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
Posted on Jun 04, 2008
AlmostBob
  • 550 Answers
SOURCE: bosch nexxt 3300 dryer not heating
with the dryer unplugged 220v is not fun
with a meter, and first disconnecting cables to each component and reconnecting them after the test is complete
check the continuity of the element, it may have burned out
check continuity of the thermostats on the heater housing and fan housing,
check the interior of the fan body for sox and lint
not a solution, yet
Posted on Oct 18, 2008
  • 7 Answers
SOURCE: Bosch WTL5400 Condensation Dryer
We continuously had a similar problem with signals forever coming on after just a few dryer loads. The problem was corrected when we took the back off of the dryer and cleaned the recirculating fan and removed a rubber glove that somehow came through the system and blocked the air flow at the heating element. Low air flow is the same as plugged filter and apparently the computer in our German-made Bosch dryer simply says that. We cleaned the area well, removed all traces of the glove and restored the dryer to operation. We have not had the filter problem since. We routinely clean the heater area at the back of the dryer to maintain our sanity. And we now dry our clothes. Bosch never responded to my query.
Posted on Oct 25, 2008
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
E1 code. water is being pumped out dry and start dryer and 3-5 min code comes back. cleaned everything inside checked all hoses and switch. everything looks fine
Cycle is interrupted and ''E1'' appears in display.
Condensate hose is blocked in some way. Turn off dryer and check hose.
Condensed water not pumped out (WTL 54 condensation models only). Pump failed.
25808741-gtkp3url2ghtdqenstp5bokb-1-0.jpg Dado
Aug 04, 2015 | Bosch Axxis WTL 5410 Electric Dryer
My Bosch wtl6304 condenser tumble dryer keeps indicating empty filter light and bleeps rapid. It warns me twice like this then trips the thermostat out. I have cleaned filter, washed the condenser out and...
never really heard of a condenser model dryer before however it does seem like internally its full of lent inside of the dryer housing itself around the heating elements if you have a large air compressor open it all up and spray air into everything in the dryer where you see lent build up this will force any lent out of the dryer and it should hopefully run as the day you first got it ;P found this to be an issue even with an LG TROMM dryer i opened up and wasnt drying very well
May 06, 2017 | Bosch Axxis WTL 6307 Electric Dryer
Bosch wtl 5100 - spins but doesn't create a hot air flow.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101.
Oct 02, 2010 | Bosch Axxis WTL 5400 Dryer
Feb 02, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Dec 28, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dec 15, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Condenser dryer cutting out
Hi
There is typically a thermal heat sensor AND a thermal trip. I suspect the heat sensor is fluffed up too...
Oct 10, 2007 | Bosch Axxis WTL 6003 Electric Dryer
Dryers Logo
134 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
