Question about Konica Minolta Konica 1015 1120 1212 Toner Black 947-136
On Konica 1212 what does J11 mean and F54? - Konica Minolta Konica 1015 1120 1212 Toner Black 947-136
    Habit-Forming:
    New Friend:
  • 106 Answers
J11 means Jammed on 1st paper feed tray & F54 means your key swith is Open(disconnected).
Posted on Dec 08, 2014
How do we reset j12 on konica 1212
power off then depress 2 and 5 and power on
Mar 28, 2016 | Konica Minolta Office Equipment & Supplies
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
Need to know what the error codes mean on a whirlpool cabrio model wtw6400sw3 F54,F82,F83,F84. Please help.
you may have something between the tubs or your bearing is going bad . does it sound like a jet plane in spin cycle?
Feb 20, 2013 | Whirlpool Washing Machines
KONICA 1015 COPIER - CODE J11, BUT THERE IS NO PAPER JAMMING THAT I CAN DETERMINE WHEN OPENED UP
check the sensors, clean it or check the wire connection of the sensors maybe it was eaten by rat.
Mar 25, 2010 | Konica Minolta Office Equipment & Supplies
F54 error code
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
Sep 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a konica photocopier modeal 1212, it doesn't work at all and shows P27. what does this means. thanks
The P 27 code is the change the toner.Please change the toner close the doors if the machine it turn OFF press and hold the 4&5 keys and turn ON the copier.Change using the ZOOM key 47,50,51,52 and press the START button the perform the toner setting.
Aug 13, 2009 | Konica Minolta Office Equipment & Supplies
Pls. my Konica 1212
power supply went bad!
try this Reseat CN15 on CB than check the oporation of L1 L2
47 mode 00
hope that help
Oct 11, 2008 | Ricoh Aficio 1013F Copier
Error code F35 on my konica 1212 photocopier
That's a fuser error condition...I'll have to get back to you because i have to check in my book to remember how to reset it...Thank you for your patient !
Mar 19, 2008 | Office Equipment & Supplies
Konica minolta 1216
1. A fan irregularity signal, excessive current draw due to binding. Examine M4 for obstructions which may bind the fan. Check the M4 fan lock signal (main CB, CN26-4) in the 47 mode, input code 42. The voltage should be between 0.1 to 0.2V DC. If 5V DC is present, either the fan is binding or the fan is defective. Replace M4 (p/n 25HA80512).
Note: If the fan lock signal is normal, install the version 17.0 EPROM (p/n 101517-17.0) to prevent false F54 errors as outlined in 1015/1212 Technical Bulletin #15.
2. IC7 on the main CB has shorted due to a failed total counter. IC7 shares the 24V DC control signal line with the exposure lamp, separation solenoid (SD1), registration solenoid (SD2), total counter, key counter, and cooling fan (M4). All loads except the total counter operate in diagnostics.
Replace the total counter (p/n 466088201) and the main CB (p/n 25HE-7312).
3. A poor connection between the cooling fan (M4) and the main CB. Reseat CN73 at M4 (cooling fan) and CN26 on the main CB.
Dec 19, 2007 | Office Equipment & Supplies
Kenmore Oasis F54 code
F54 = Motor Control Overcurrent
Does the basket turn freely? If not, determine cause of friction.
There is a detailed repair manual inside the machine. If you open the top of the machine with a screw driver in the front you will find the manual on the inside of the front panel. Good luck
Dec 09, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Konica Minolta Konica 1015 1120 1212 Toner Black 947-136 Logo
115 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
