Question about Lasko Heating & Cooling
Cant get the lasko cermamic heater to work on auto at 69 degrees
Setting it on auto at 69
5 Suggested Answers
FurnaceGuy
  • 74 Answers
SOURCE: heater wont stay on long enough to maintain manuel
Either you unit is undersized or you heater may be broken. Have you change your air filter lately?
Posted on Jan 04, 2010
  • 3287 Answers
SOURCE: The heater will not kick on. It's a programable 7
Change Temperature Setting Until the Next Program Period (Temporary Change)
? Press UP Arrow or DOWN Arrow until the screen shows the desired temperature setting.
NOTE: The temporary temperature setting is displayed for about 3 seconds and then the room temperature is displayed.
Temporary appears in the display. The setting cancels when the next program period starts or when
you press RUN PROGRAM.
Change Temperature Setting Indefinitely (Hold)
? Move the System switch to the desired position (Heat or Cool).
? Press HOLD TEMP then UP Arrow or Down Arrow to change your setting if desired. (The display changes from showing the setpoint
temperature to room temperature after approximately three seconds).
? To cancel Hold press RUN PROGRAM.
The downloadable manuals for this t-stat are here, and the addendum, here. Page 17 and 18 detail thermostat operation I have copied above. It has graphic representations of keys that do not copy over very well, so if you have questions about the steps above, you should view the manual in the links provided above.
I hope this helps! Please take a moment to rate my reply - thanks!
Posted on Dec 23, 2010
  • 67 Answers
SOURCE: THEMOSTAT WILL NOT GO HIGHER THAN 69 DEGREES.IS
That the max setting the heater. Ken's Repair
Posted on Jan 19, 2011
ercupa190
  • 12223 Answers
SOURCE: manual for lasko electric heater model 5805
go to www. fitness.manualsonline.com + www.retrevo.com
God bless you
Posted on Oct 10, 2012
How do I regulate temp on my lasko heater
My experience with Lasko heaters is with the small portable ceramic types. On mine there are two knobs. One is the "Power"; the fan symbol is for fan only, then (I) Low Power and (II) High Power 1500 watts. The other know is the thermostat from (-) to (+). Set the thermostat towards (+) until the temp in the room is the way you want it. Then turn the thermostat know towards (-) until the unit shuts off. This is now the temperature setting and the heater will cycle on and off to this setting. Hope this helps.
Jan 05, 2014 | Lasko Ceramic Heater
Lasko 5141 - I set the temp to hold @ 68 degrees at night but it seems to ignore the setting and gets into the high 70's. This is with the rotation switch on if that makes a difference. Any Help ? Thanks
Remember it is always colder at the floor level, the heater is pretty close to temp when it is above 40 degrees outside, but as the temperature gets colder outside so does the temperature at the floor level in your house because heat rises.
I use my house furnace thermostat mounted half way up the wall as a guide, When the temp outside is in the teens, I have seen as much difference between the floor temp on the heater and the wall to be 4-6 degrees different. So this means as the tempurature outside drops you need to regulate the thermostat on the heater downward to compensate for the colder floor temperatures.
Jan 10, 2011 | Lasko 5141 Ceramic Electric Heater
Our Lasko 5620 has a digital control, but we can't set the temperature. It says at 76 degrees, no matter what we do. Hitting the control buttons does not work.
Based from your comments, it seems that you have a
defective digital control. Have a check up for this item.
It may need to be replaced. Hope this will help you.
Jan 10, 2010 | Lasko 5610 Baseboard Heater
The thermostat does register the right temperature.
Your heater might be on the Auto settings .. it will turn on and off itself once the pre set temp is reached ...
Jan 05, 2009 | Lasko 5365 Ceramic Compact Heater
Heater won't get hot
I went on several websites until I located the company. Recieved a call from them to day and they are sendin me a manual.
Dec 15, 2008 | Lasko 5520 Ceramic Compact Heater
Model 5800
In page three in the manual it shows you how to set your temperature settings.eb6548e.jpg
Oct 30, 2008 | Lasko Ceramic Heater
Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Dec 13, 2007 | Lasko 5365 Ceramic Compact Heater
Heating & Cooling Logo
Top Lasko Heating & Cooling Experts
Steve Oakes
Mack Baxter
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
