Question about Car Audio & Video
I have 2 q power 15 4ohm. How do i wire them up to my a2300hct
    Top Expert:
  • Car Audio & ... Master
  • 74,377 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Wiring diagrams to may popular brand Car Stereos are given with illustrations.
Posted on Dec 05, 2014
Heeey. I have the Audiobahn A2300HCT and it has a very strange problem. When i start the amp its in the normal blue mode but i have no sound. The one power output (LEFT) indicator shows +3DB (full) the...
My brother just bought an A2300HCX and almost the same thing happen. 1 of the gauges (left side) was no movement. We tryed hooking the amp to the right side, and it works. The Left side turns out was shot, had to get it fixed. So sorry to tell you but sounds like one of the channels has internal damage. I know this isn't the good new you were wanting to hear, but hope it was helpful
Apr 08, 2010 | AudioBahn A2300HCT Car Audio Amplifier
Trouble with pioneer radio
when you touch the wire (hot) power to the radio does the face light up? make sure the ground wire is hooked up also.. or it won't show power
Mar 19, 2010 | AudioBahn A2300HCT Car Audio Amplifier
A3200e wattage
Here are some specs:
  • 4800W Max, High-Current 2-Channel Car Amplifier
  • RMS Power Rating:
    • 300 watts x 2 chan. @ 4 ohms
    • 600 watts x 2 chan. @ 2 ohms
    • 1200 watts x 2 chan. @ 1 ohm
    • Bridged:
      • 600 watts x 1 chan. @ 4 ohms
      • 1200 watts x 1 chan. @ 2 ohms
      • 2400 watts x 1 chan. @ 1 ohm
  • Max Power Output: 4800 watts @ 1 ohm
  • this is the web site I got the specs from
  • http://www.sonicelectronix.com/item_61_Audiobahn+A2300HCT.html
  • Hope this Helps...
  • Jul 22, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    I'm working on an audiobahn A2300HCT and it seems to have a dead short in the front end of the power supply (The fets,caps and rectifiers will all have to be pulled, one at a time.Any suggestions?
    Hello rick27,
    I'm assuming that you have already pulled the board out and cannot visually locate any out of place looking component and that you've inspected the board for solder bridges, broken pieces of wire, and other signs of FOD.
    If this is the board you are looking to troubleshoot, I'd start nearest the fuses and work systematically from there. You can test many components if you just remove one lead from the circuit. Both diodes and capacitors can be field-checked quickly with one lead disconnected.
    Jul 16, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Reversed 12 volt and ground wire when i installed it...now the red light is on AudioBahn A2300HCT
    check for a short or burnt trace by the negative (ground traces) on the power side of the board
    Jul 04, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    HEY I HAVE 4 GAUGE GROUND & POWER THAS WHAT THE AMP ALLOWS. I TRY 0 GAUGE BUT IT IS TO BIG FOR THE AMP. A2300HCT.
    Hello again VICENTEMULGA,
    Audiobahn's website has apparently been shut down and it's my understanding that they are no longer manufacturing any new products. And not supporting the old ones, online anyway.
    But I did find this site that sold the A2300HCT and still have the specifications listed. The 3rd from the bottom in the description shows "1/0- or 2-gauge power and ground leads recommended".
    At the very least, you should consider running 1/0 or 2-gauge from the battery to a distribution block and then run a very short jumper from the distribution block to the amp.
    May 05, 2009 | AudioBahn A2300HCT Car Audio Amplifier
    Red status light on no power goes to my subs
    no but u only need one. it needs to be no more than 10 inches from the positive battery terminal.
    Apr 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
    Wierd stopped working audiobahn a2300hct
    Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
    Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
    A2300hct no aound
    are there power to the output transistors?
    Aug 06, 2007 | AudioBahn A2300HCT Car Audio Amplifier
    Audiobahn A2300HCt wont work
    you might not have enough power pushing the amp.... I have two batteries and two caps running
    Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
