Question about Dishwashers
Asea Cylinda 1400 dishwasher not filling. Keeps waiting for water to fill. Continues normally if manually add water. Tap is on and water available.
Test that it works OK when adding water manually and closing door. Occurred after it flooded the floor and wouldn't drain. Turned off, reset the house electrical fuse. Let it dry out. Attempted to use normally.
  • 2,210 Answers
The incoming water valve is faulty. Look at the back of the machine where the hose connection runs into the machine, there should be a solenoid operated water valve there. Check that out or replace it.
Posted on Dec 05, 2014
Hobart dishwasher overflowing it is a c44a in manual it continues to add water when running
If it continues to put water in machine when switched off then fill solenoid, if not then possibly level sensor
Jan 22, 2018 | Hobart Dishwashers
Need a timer motor for asea cylinda 1200 dishwasher.
Standard appliance parts, Appliance parts incorporated, even Sears will have parts available generally.
Nov 09, 2015 | Dishwashers
Asea cylinda
go by manual so you dont mess up
Aug 08, 2013 | Dishwashers
Where can we obtain an instruction manual for the above dishwasher please Bosch Classixx SRS55CO2 GB/13
Hi and welcome to FixYa, I am Kelly
Go to this link:
http://unitedkingdom.boschnew.en.nectar-farm.com/customer-service/download-product-manuals.html
The click on download manuals and a new window will open.
You must enter ONLY this model number in the search window center page:
SRS55C02GB Find your manual /13 on the list and download the manual.
Thanks for choosing FixYa,
Kelly
Jul 14, 2011 | Dishwashers
Manual for Asko ASEA 1400 dishwasher
You can get the manual on the link below. It is uper right corner next to the man under the pdf. You will have to click on the stars to download.
http://safemanuals.com/user-guide-instructions-owner-manual/ASKO/1400-_E
Good Luck and please rate 4 thumbs up for the freee answer
Apr 24, 2010 | Dishwashers
Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Sep 30, 2009 | Dishwashers
User Manual of Asea Cylinda 1200 Dishwasher
One of these was in my house when I moved in, still have the manual. Very efficient dishwasher.
A is a prewash (machine will stop after it). Manual says it's meant to rinse stuff while you wait until you've filled the machine to run a full wash.
D is economy wash. Water is heated according to the switch you select on the front.
C is a prewash that will continue on to D (normal cycle). Water is at incoming temp.
B is another prewash that will continue on the C etc (heavy cycle). Like C, water is at incoming temp.
E is dry cycle. Heating element is on/off depending on switch on the front (dunno why you'd turn it off..)
While turning the dial, push it in and it will stop exactly at the start of theach cycle.
Mine has stopped emptying, think the pump has died, looking for a replacement..
Apr 25, 2008 | Dishwashers
Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Apr 02, 2008 | Asko Washing Machines
Dishwashers Logo
117 people viewed this question
Top Dishwashers Experts
