Question about Microsoft Kinect Sensor for XBOX 360
Can I make my Xbox 360 kinect sensor wireless as I would need a really long cord to plug it in
    Master:
  • Microsoft Master
  • 330 Answers
Sorry but no. You can pick up a Xbox Kinect extend link cable. There is a 15 foot cable for $19.99 usd. Try this site. Xbox Kinect Extend Link Cable
Posted on Dec 18, 2014
3 Suggested Answers
nikkiallisto
  • 258 Answers
SOURCE: hey i have a plasma tv which is 50HZ/60Hz but
Hi there are you using hdmi cable or avi cables?
Posted on Jan 15, 2011
JT_Alabama
  • 13 Answers
SOURCE: does a bluetooth earpiece work
No a bluetooth headset will not work with the Kinect. The Kinect has a mic built in to the unit to pick up sound from the entire room.
Thank you for using FixYa!
Posted on Feb 28, 2011
The problem with the kinect is C000022D
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-5.aspx Red light on the Kinect sensor Last Modified 4/22/2011
Page Content kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive one of the following errors:
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.​ ​ ​ Solution 2: Check the cables ​ ​new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, please contact Xbox Support
Jul 19, 2011 | Video Game Consoles & Games
XBox Kinect says insufficient power I've tried unplugging and plugging into a single outlet but same problem. What can i try next?
Red light on the Kinect sensor Last Modified 16/05/2011
kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive the following error:
The Kinect Sensor has insufficient power (C0051202)
If you still get the same error message, try the next solution.? ? ? Solution 2: Check the cables ? ?new360cableconnect.jpg
Xbox 360 S console
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light, your cable needs to be replaced. Contact Xbox Support.
If these solutions do not solve the problem, the sensor needs to be repaired. To start the online repair process, go to myservice.xbox.com.
Jul 04, 2011 | Video Game Consoles & Games
My kinect is not workin on the kinect its self only the red light is on and no green what is wrong and it is askin if my power supply is plugged in
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light your cable needs to be replaced. Contact Xbox Support.
Other solutions can be found on the Xbox support site by following the link below.
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-1.aspx
Mar 08, 2011 | Video Game Consoles & Games
How to connect the xbox kincet
If your Kinect only has one cord coming off of it, that should go into the back of your Xbox where there is a color coded slot (orange).
Feb 28, 2011 | Microsoft Xbox 360 Console
Trying to connect the kinect
First off make sure you have at least 190 mb of space in your HDD before trying to set up your kinect.
Setup:
Step 1: Make sure your xbox 360 is properly connected to the television with the AV cables and power cable to an outlet.
Step 2: Place sensor under or on top of your television on a stable flat surface.
Step 3: Depending on your xbox the sensor has two different connections. If you have the new slim xbox 360 then you do not need the extra add on connection you simply connect it to a special port for it on the back of your xbox 360 slim. If it is a older version xbox then you will need the extra power adaptor since it will not work without it.(Cable with power connection)
Step 4; (ONLY FOR OLDER VERSION XBOX 360): If you have a wireless connection adaptor unplug it from the usb port in the back of the xbox 360 and connect the kinect sensor's power adaptor into the port you took the wireless connection adaptor off of. There should be a special cable that will act as an extension for the wireless connection adaptor you unplugged this is so you can connect it directly to the usb ports in the front of the xbox 360. Then plug the end with the power outlet connector of the kinect sensor power adaptor into the wall socket.
Step 5: Turn on the xbox 360 and the kinect sensor should move up and down to adjust.
Step 6: Put kinect game in and it will guide you through kinect settings and your on your way to start playing! Have Fun!
Feb 26, 2011 | Microsoft Xbox 360 Console
I.m trying to play a kinect game and the kinect tuner gives me this error code (coooooc2)
Hi Chris
Kindly specify if you have a "slim" version of the Xbox 360 or the older one?
The error code you have specified here seems to triggering due to a hardware issue of your Kinect device.
If you have a older version of Xbox 360 which requires you to use a separate power supply for Xbox 360 try these steps
Post that re-calibrate your Kinect tuner and check if it's working else you may have to get your Kinect device replaced from Microsoft
Jan 02, 2011 | Microsoft Xbox 360 Console
Trying to install kinect to xbox 360 get error message C00000C2
Welcome to Fixya!
Solution 2: Check the cables Xbox 360 S console
    Xbox Support.
  4. Turn on the console.
?Thank you for using Fixya!
Jan 01, 2011 | Microsoft Xbox 360 Console
Trying to connect kinect.... its saying that it has insufficient power
Hi Eddie,
Try with different USB ports if you are using old XBOX and getting message as " insufficient power". It seems to be a adapter issue why don't you visit store and exchange the XBOX 360 Kinect device.
Thank you for using Fixya.
Xbox 360 kinect Games List
Dec 25, 2010 | Microsoft Kinect Sensor for XBOX 360
Microsoft Kinect Sensor for XBOX 360 Logo
138 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
