Question about Ingersoll Rand Air Tools & Compressors
Ir machine tripping on bearing oil temperature
IR NIRVANNA N110
    Problem Solver:
  • 13 Answers
You know that the ingersoll rand has a protection of your unit. The tripping is normal when your machine is high temperature, that is to avoid your machine screw contact the discharge side of your airend.
Hopefully it can help.
Posted on Feb 04, 2015
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 22 Answers
Check you air cooled oil cooleer for debris.
Posted on Jan 03, 2015
Porrelli
  • 167 Answers
SOURCE: how do you check oil level on a u20 ir compressor
Hi
No mate, you check it when the pump is not running.
Don't over fill it or it will pump oil into the tank.
That's bad news if you want to paint.
The middle of the sight glass is the correct level.
Don't let the oil get too low either.
The pump lubricates by a dipper on the bottom of the conrods. Too low an oil level starves the top end of oil and causes premature wear.
Regards Andrew Porrelli
Posted on Dec 07, 2009
  • 432 Answers
SOURCE: My compressor 2475 ir (5hp) has no dip stick or
In the owners information your compressor takes the 1 bottle of IR oil that comes with it. If you have a local tractor supply company or another company who carries IR you might check with them, it is the only oil i would recommend for your unit.
Posted on Jul 31, 2010
  • 1274 Answers
SOURCE: Ingersoll Rand SS5 Cast Iron
Hi, my name is John. Welcome to FixYa. You can get it here www.mastertoolrepair.com . Thanks for choosing FixYa...John
Posted on Nov 27, 2010
  • 205 Answers
SOURCE: unloader ir t30 not operating tripping motor
the unloader is made into the pressure switch. When unit shuts down you should hear air blow out at the bottom of the pressure switch for a short period and stop.If it continually blows until the unit tries to start the tank check valve needs to be replaced. the check valve is located in the top of the tank where the discharge line goes into the tank. Also if you check the bottom of the pressure switch with the cover off you will be able to see the unloader. It's a schrader valve that is hit by a small arm on the pressure switch. you can replace the schrader valve. if it's something on the pressure switch the switch should be replaced. I've seen check valves bad but very seldom do you see the unloader bad. hope this helps you.
Posted on Jul 10, 2011
  • 205 Answers
SOURCE: We have 2 IR air
First what temperature is it tripping at ? Have you removed the oil fill plug and visually inspected the oil level. It should be filled to the oil fill plug threads. 228 degrees F is the temp the air end temp sensor should trip the unit at, approx. You need to know the ambient temp. where the unit is located. add 100 degrees F to the ambient and that is what the unit should be operating at. ( ex. 100 + 95 amb compressor should operate at approx. 195 degrees F.) If the unit is tripping at 180 or even 215 you probably have a bad temp sensor. It would be unusual for 2 units to have temp sensors go bad at the same time but it could happen. OK if the unit is tripping at or around 228 check the following: Oil/air cooler - (Radiator). It should be clean on both sides. It can be blown out with air or washed out with a 1200 psi pressure washer. When complete you should be able to see thru the cooler, and have good air flow thru it at any location especially corners. Next the thermostat could be the problem. when starting the unit up cold check the return line from the cooler with your hand. If the panel reads 190 to 200 their should be oil flowing thru the cooler. if it stays cool replace the thermostat. The thermostat should open at 170 degrees F. If you have a temp gun use it to check temps on the 3 lines from the thermostat. you are looking for a 25 to 30 degree drop across the cooler. Last but not least if all looks good and the unit is just prematurely tripping you may have a controller going bad. Sometimes these controllers will trip on some alarm. At first it may be once per month then once per week then once per day then several times a day until it gets to where it will not run without tripping on some alarm. Good Luck.
Posted on Sep 07, 2011
E000225 0001
Oh, it looks like your ImageRunner's fixer unit (the heater thermistor it uses to regulate temperature) burned out or disconnected on you. http://canon-ir-6000.blogspot.com/2009/02/e000-main-cause-main-thermistor-th1-has.html
Find that little sensor leading up to the coils and replace it.
Otherwise, say that again in just Hindi?
Aug 04, 2014 | Canon Crtdg, gpr15, ir 2270/2870, bk
Sir i have cannon ir 3530 xerox machine that shows 002 my cell no 9833273003
fuser temperature not rising....try to reset in service mode * 28 *, function, clear,err
Dec 12, 2013 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
F2 low temp
The most common probem is burned wires going to the heater on the top of the oven cavity. Typically you will see the coating on the wire close to the heater all cracked and bare. You can usually just cut the wire back an inch and pull some slack up and reconnect the wire and you will be good. In some cases the wire will be burned to much and the whole wire will need to be changed. Any oven repair shop will sell you these high temp wires. DO NOT use regular wires they MUST be high temp rated.
Here is some other things to check if the heater wires look good.
COMPONENTS
IR Element
The IR element - a dual coil type heater - is located
in the bottom of the oven cavity. The first coil is the
heating coil. The second is the IR thermocouple
wire. The heating coil outputs 3000 watts at 208
VAC. The heating coil's resistance is 14.4 ohms at
room temperature.
The thermocouple coil is a Type K thermocouple
with a resistance of approximately 20 ohms at the
splices located approximately 6 inches from the
heater and 40 ohms measured at the extension wires
at the I/O control board.
The IR element is controlled via the K5 solid state
relay and the IR thermocouple via the I/O control
board.
Also try this
1. Verify the high-limit thermostat is not tripped.
o If high-limit is tripped, reset and allow the oven to warm up.
o If high-limit is not tripped, follow the instructions below.
High-limit thermostat is not tripped.
Place a small water load in a microwave/heat-resistant container
(approx. 275 ml) in the oven and place the oven in TEST MODE. Press
the MGTRON key to actuate the microwave. While holding down the
MGTRON key, watch the CC and IR temperatures. If either temperature
bounces substantially, there may be a noise (EMI) problem.
To correct this problem, examine the wire routing for each
thermocouple wire. If the wires are routed near any high voltage
components such as the magnetron or high voltage transformers, reroute
the wires. If this does not correct the problem, verify that both
magnetrons are securely mounted.
Good Luck
May 20, 2010 | TurboChef TORNADO Electric Oven
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
PLEASE HELP ERROR CODE
The machine's hard drive has died. you will need to get a Canon technician out to replace it for you and to re-install the machine's system software. In addition to this you will also need to reconfigure some of the machines settings such as the address book, as this is usually lost when the hard drive is formatted or replaced.
May 07, 2008 | Canon imageRUNNER C3220 Color Copier
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ reception@biscayneroofing.com
Thanks
Madlyn
Feb 25, 2008 | Canon (6981A002AA) for imagerunner 2200,...
Air Tools & Compressors Logo
77 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
