Question about Pool & Spa
Why would my pump not turn off sometimes, unless i unplug it.
  • 9,771 Answers
The timer that controls the run time has a stuck contact or isn't running at all.
Posted on Dec 05, 2014
Water pump shorted out. Now will not stop running unless washer is unplugged
oops you shorted the control board and now it needs more fixing at more expense
Jul 13, 2016 | Kenmore Elite Oasis 27052 Top Load Washer
How long does it take to fully charge a vector smart battery charger? When I unplug it, it won't power on unless it is plugged in. it is a VEC 1092 a model
The initial charge can require several hours, sometimes overnight. After that, recharges require less time. If your device doesn't turn on unless connected to the charger, the battery may be dead.
Apr 18, 2016 | Vector Camping, Backpacking & Hiking
Van sputters when you put it in gear after its been started multiple times
Bad fuel pump, stopped up fuel filter, mabey? First check for vacume leaks.... may try unplugging the throttle position sensor. Plug it right back in... just check the connection.
Aug 02, 2017 | 2002 Kia Sedona
Hitachi 55VS69 screen goes black and there is no volume and it will not turn off unless unplugged.
The key here is you have to unplug it---it means the problem is related to the microprocessor which may become confused because of an issue elsewhere in the set---no real easy answer except it may be expensive to locate and fix.
Mar 19, 2012 | Televison & Video
Code "F02" sometimes pumps out water sometimes
F-2 Long Drain
If the drain time exceeds eight minutes, the water valves are turned off
and "F/02" is flashed. Press PAUSE/CANCEL two times to clear the
display.
NOTE: After four minutes the "Sud" error will be displayed, then four
minutes later the "F/02" error code will be displayed.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and
make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Here's the handy Hippy with a nice video
Here is a Duet HE washer service manual
Thanks for using FixYa
Jan 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I replaced fuel pump and relay switch Sometimes when you turn key you can hear relay switch clicking and pump working then truck satarts, Runs fine . Try start it again and it just turns over , there's...
not knowing what kind of vehicle it is it is hard to tell. some gm cars and trucks have oil sending units that will not allow the vehicle to start unless it has oil pressure. they start going out and sometimes they start and sometimes they won"t.
Dec 08, 2010 | GMC Sonoma Cars & Trucks
LD appears. I cannot shut off unless I unplug it
Long Drain you may have a something in the drain hose or drain pump or damaged drain pump.
“Ld” flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.  Press STOP/CANCEL to clear the display.
Sep 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
My sebring sometimes won't start even though it
Sounds like a faulty fuel pump. Next time it doesn't start have someone listen with their head right above the gas tank. When you turn the key to "on" pos, without trying to turn it over, they should be able to hear the pump spin.
Aug 10, 2009 | 2000 Chrysler Sebring
The water wont go out of washer.
  1. Turn of the machine and unplug it.
  2. Check if the filter is clogged.
  3. Check if the pump turbine is clogged.
  4. Check if the drain hose is close.
Unless the pump is dead it's most likely that one of those 3 are clogged.
Apr 24, 2008 | Washing Machines
Pool & Spa Logo
37 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
