Question about Coffee Makers & Espresso Machines
Turn on machine and machine goes through Setup phase and then advances to indicating 'Rinsing' and Warming up.
Have left the machine turned on overnight but still no change. Have attempted several power on and off but still now change.
  • 691 Answers
Sounds like the heating element has died. Use a multimeter to check out the continuity and resistance through the element to see if checks out.
Posted on Dec 13, 2014
5 Suggested Answers
  • 46 Answers
SOURCE: Gagia Scyncrony
try a good de scale of the tank and pipe work . remember to rinse / flush well with clean water afterwards. limescale in the smallest form can be a major cause of most faults!
Posted on Feb 09, 2008
Richie_asg1
  • 1036 Answers
SOURCE: Krups FME2 will not flow water.
Does it sound like it is boiling water at all?
If it is boiling, but not giving hot water, then the one-way valve is stuck.
If it is not getting hot (on the soleplate base) then usually the element has blown.
These machines use the steam generated by boiling as a means to move the water up - like a geyser, and need the heat to move the water.
Replacement elements are available, and the valves usually just require cleaning.
Posted on Jun 29, 2008
mirran
  • 515 Answers
SOURCE: Machine is stuck on the
Try to make a cup of water (same as you make tea), it can also be that the element is full of calcium and then the sensor not get the right value to send to the electric board. If your element is full of calcium then you have to replace it.
Posted on Jul 11, 2008
  • 81 Answers
SOURCE: when I turn on the machine it says warming up and
Probably overheat protector thermal switches on the water boiler is tripped. Need to open the machine and reset those switches by pushing in the pins on the switches.
OR the element on the boiler is blown.
Posted on Jun 09, 2010
Humidifier is not warming. Indicator light had
reset the humidifer, Turn off, wait for 3 minutes, and try again.
If the problem persist, see your owner manual go to the website from the supplier and get support via ONLINE chat for fix it.
God bless you
Oct 12, 2013 | Philips Respironics Auto BiPAP Machine...
It is a new Saeco Odea Go machine. Every time I turn it on the indicator lights flash up and down successively and a half inch of water comes out of the coffee spout. The light is then in the ready...
What will the machine do when you turn it on? The green light will start flashing for warming up phase. When it reaches the working temperature, all the lights start flashing in anticlockwise direction and the brew group moves up and start pumping water to rinse the system.Of course half an inch of water will come out from the spout. That is normal.
Sep 10, 2010 | Saeco Odea Go
When I turn on the machine it says warming up and rinsing but it doesn't rinse and I can't get it to make a coffee it won't go past rinsing
May 25, 2010 | Saeco Royal Digital Plus Coffee...
Cannot solve "Ventilate" problem - weater circuit is broken
Turn the knob on after you press the hot water button, run the cycle until the message is gone takes a few seconds or about 2 ounces of hot water.
May 02, 2010 | Gaggia Titanium Espresso Machine
Saeco Royal Professional is stuck on "Ventilate"
Hi
There are possibly 2 things that it could be.
1. Check that the tip of the wand is not plugged.
2. Your solenoid valve that controls the water is bad or stuck. That means a trip to the service center.
Apr 17, 2010 | Saeco Royal Professional Espresso Machine
Machine will not move past Warming Up start up
check with voltmetar your element on boiler for espresso,element need have continuidi,and check reset button if your machine have button on tank,and check small fuse on tank(with white rubber around)
Aug 24, 2009 | Saeco Royal Digital Plus Coffee...
Rinsing...Warming UP... message on Saeco Magic Comfort plus
HI, I am sure you have solved your problem, however:
If you Descale the machine and let it Rinse to complettion of the
cycle; it resets the machine and it will start Rinising after warmup.
Otherwise press the Menu button and go to Energy Saving
then press the Esc buttton. This allows the machine to start
without Rinsing. Also you may turn Rinsing to Off in the Menu.
Nov 04, 2008 | Saeco Magic Comfort Plus Espresso Machine
Sleep Mode
Yes there is.But let me give you an explaination of somethign in the scanner.Once you turn the power save mode off, If the copier has sat for a while and saws WARMING UP, It is not the power save setting. The scan lamp also has to reach operating temperature for the machine to run. So even after Power Save is off, you may get an occcasional Please wait Warming up before a copy. There is no settings or changes for the scanner lamp warming. I throw that in so you don't suspect you did something wrong in changing settings.
Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  1. Press the [Enter] button. 'Machine Setup Tray 1 Size' will be displayed.
  2. Press the [Left] or [Right] arrow button until 'Power Save' is displayed, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button to select 'On' or 'Off' to enable or disable the Power Save mode.
  4. Press the [Enter] button to save the setting.
  5. If Off is selected, skip to step 9.
  6. If On is selected, press the [Left] or [Right] arrow button to select the required time interval.
  7. Press [Enter] to save the setting.
  8. Press the [Stop] button to return to the Standby mode.
Jan 11, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Gaggia Syncrony no longer rinses during the selftest
Rinse option is in the menu. Click on Rinsing and turn it on.
That should be it.
Saeco and Gaggia Service Center
Coffee Beans, Espresso Machines, and Cleaning Supplies
www.cerinicoffee.com
Nov 03, 2007 | Gaggia Syncrony Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
