Question about Toshiba Televison & Video
What do I do if I have audio but no video except for the off/on light.
I have tried reseting it by removing power for one minuite then plugging it back in.
  • Toshiba Master
  • 10,291 Answers
Shine a flash light on the screen up close when the TV is on. If you can see anything at all the board that controls the white light isn't working. If you see nothing then the board that controls the picture is bad. This board has one or more flat ribbon cables running to the bottom of the screen.
Posted on Dec 05, 2014
Testimonial: "Thanks for the assist Lawrence. I feel that it would probably be cheaper to replace the TV than to try to repair it."
  • 1 more comment
  • Lawrence Oravetz Dec 06, 2014
    Oh, don't give up so easily. I spent 36 dollars to replace a bad screen controller board on my Sharp aquous TV. Took 1/2 hour to make the TV operational
  • Dave Blower
    Dave Blower Dec 07, 2014
    Is that a do-it-yourself or do I take it to a repair station?
  • Lawrence Oravetz Dec 07, 2014
    It's a do it yourself job. www.shopjimmy.com will have every part you need for the repair.
Model: LC-70LE732U Problem: No audio or video. Error code: flashes 1 long, 1 short Tried: Reset to Service Mode: Replug W/ holding Input + volume down Response: solid light for 10 sec, returns to...
According to the information I have on error codes for that set this is a back light issue. Try removing the plugs to the back lights then plug the set in and see if you have normal voltage, if you don't it may be a power supply issue but I think your going to find the voltage is normal with the plugs unhooked and they drop off if they are hooked up, meaning you have at least one bad back light strop
Oct 18, 2017 | Televison & Video
The yellow light comes on inside but the computer won't come on neither does it beep?
First remove any power cables and batteries(if laptop) from your system and hold down the power button for 15 seconds.
Plug the power cable back in & attempt to boot.
If this does not solve your problem then you will need to remove all non-essentials from your system.
If laptop, this simply consist of battery, ram, optical drive & any other removable bays or devices. Unplug all cables except the power cable & attempt to boot.
If desktop, you will need to remove any cables plugged into your computer except keyboard, mouse, power, video, sound, & network cable. Open the case & remove any PCI cards, except video cards, unless you have on-board video, unplug the data & power cables going to the optical & hard drives. Now attempt to boot. If you have no luck you can remove your RAM sticks & try again. If you get an error beep warning you about no ram then you might have a bad ram stick. If none of the above works then you may have a bad power supply or motherboard. Power supplies are pretty easy to test with tester or use a spare.
Jul 16, 2012 | Dell Computers & Internet
My new gaggia accademia won't work. It shows error code 19. Can you help me?
Hi, Error 19 is not known by me. Sounds like something is not resetting or has failed. Try turning off the machine at the main power switch and unplug it from the wall for a few minuites. Remove the dreggs draw and drain tray and replace them before you plug it back in. This will allow the machine to reset. Dazza REPAIRER
Sep 24, 2011 | Gaggia Coffee Makers & Espresso Machines
My Sony Music system DVX MP3 is not getting on when the power button on the music system/remote is pressed. The red light is blinking. Please let me know what is the problem?
Possible that the output is short as the protect is shutting off the system.
remove off the speakers and try once again.. If not remove plug and keep aside to reset or try to depress menu/select while power plug is put into.
If the fault satys you will have to disconnect the output, power to sub circuits and check if the set triggers.
Make sure the mP IC gets voltage and reads remote signals.
Sep 30, 2010 | Audio Players & Recorders
Wont read disks
try shutting off console and unplug for 10 minuites to reset cd drive changes. then plug in and restart console and try loading a dvd in the drive. if the dvd plays then try your games in it again, hope his helps, tim.
Mar 14, 2010 | Sony Playstation 3 (PS3) Console
Hit power button and nothing other than lights flicker once
Remove everything from the board except the front panel hookups.Make sure you remove memory, video card, hard drive and cdrom cables, hard drive and cdrom power, anything plugged into the back except the power. If it will power up this way start plugging things back in between power cycles. Start with memory then power down. Then add video then power down. Continue with Cdrom, then hard drives. When it stopps wanting to power on you know where the issue lies. If it wont power on with nothing on it then the motherboard is probably bad. Hope this helps.
Aug 08, 2009 | Intel Motherboard
Wont turn on...front light keeps blinking? Had a power outage last night.
Try unplugging it for 5mins, to allow the internel electronics to reset. Plug back in leave for a further minuite then try it it should work.
Aug 02, 2009 | Televison & Video
2002 saturn s series total steering collumn/ignition replacement
did you give them the vin when you bought the ignition,it has to be the one for your car,also might have to relearn the key to the computer,turn key on try to start let go and leave in on position for 10 minuites turn off for 5 seconds,turn back on try to start let go leave for 10 minuites,turn off for 5 seconds ,repeat one last time,takes a little over 30 minuites,to complete,the car thinks your trying to steal it and is disableing the fuel pump
Jul 21, 2009 | 2002 Saturn Sl
No display
Try swaping your memory with a known good stick of ram.
Are you sure your monitor is good? Video cables?
Try changing (if pci) slots when installing video card.
Other than these 3 things the only pretty sure thing is; sorry, mother board or cpu.
Jul 01, 2008 | E-Machines eMachines Desktop PC
Computer gets power, but doesn't display anything
remove your video card and plug it again.. if it doesnt work..
try plugging ur video card to *********** board built in video card and then ur on-board video card to you monitor..
this is what the nvidia guys mentioned on their video while announcing the release of the 9 series
May 07, 2008 | Toshiba Satellite P25-S607 Notebook
Televison & Video Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
