Honeywell LR1322, The control has sound? What is the problem? How to fix it? Thanks
When the heather run, the control switch has loud sound, after awhile it stop and later has noise again.
Posted on Dec 06, 2014
Honeywell TH8110U1003, No heat reading, only two dashed lines, please help asap!
Sounds like the tstat communicates with a wireless remote sensor on the heating unit. The dashes usually mean there is something blocking/interupting the signal. Maybe another wireless device signal crosses its path.
Apr 24, 2017 | Honeywell Heating & Cooling
IVE GOT A HONEYWELL T87A 3 WIRE THERMOSTAT MOUNTED ON THE WALL AND WHEN I WANT TO TURN ON MY HOT WATER BOILER I HAVE TO LOWER THE T-STAT SETTING INSTEAD OF INCREASING IT TO GET THE HEATING SYSTEM TO TURN...
I would switch to a two wire heating only stat It sounds to me like they have the boiler wired into cooling side. Do you also have to set switch on your t-stat to cooling or leave it on heating. Just curious. I would still go with two wire stat. Thanks.
Nov 11, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
My Honeywell thermostat is displaying everything and the touchpad will not work. What could be the problem? We need it to control our air conditioning but it also controls heat in the winter. Thanks!
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Jun 10, 2010 | Honeywell Programmable Thermostat Heater
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
Honeywell minifridge not cooling, blinking, funny sounds
there is a 1000 Uf electrolytic capacitor on the power supply unit that was bought from a bad supplier. It's suffered a failure as they ALL did. Replacing it with a new 1000 Uf capacitor 16 volts or higher will fix it. Just remember they are polarity sensitive. i found mine at the dump and fixed it in less then 1 hour. The top of it will be bulging out and it could even leak
Jun 07, 2009 | Refrigerators
Central honeywell air conditioner
Sounds like it may have lost power. Check the breaker and the fuse at the furnace. If they are all in the on position and working then it sounds like you may need a technician. If the display is blank on the thermostat you may also want to replace the batteries.
Jun 12, 2008 | Honeywell Electronic Programmable...
Honeywell T86A3006 24V Class 2 Round thermostat 8020
The honeywell tradeline thermostat would work as a direct replacement (no mercury in the new ones), however if your using just heaters and no cooling system off of it, you could Heat only thermostat from honeywell that would replace your unit as well. Both at available at Ace Hardware with the heat only unity being roughly 7 dollars cheaper.
Jan 14, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
