Question about Kitchen Ranges
How do i get a fuse I fried what appears to be a fuse the only visible model number is on spark module model # 6545g1001c
Removed fried part
  • 2,210 Answers
What are you talking about? A cooker? Where is the owners handbook? Can you download one from the manufacturers web page?
Posted on Dec 05, 2014
Sony TV question. Lightning surge, no lights, no picture, fuse is good.I have the model number. looking at back of tv now, cover removed.
YOUR GONNA NEED A NEW TV ITS FRIED IT WHEN ITS STORMING YOURE SUPPOSED TO UNPLUG ALL ELECTRONICS BECAUSE OF THAT ISSUE
Jan 09, 2017 | Sony Televison & Video
What causes no spark ?
many things can prevent spark:
bad plugs
bad plug wires
bad ignition coil(s)
bad ignition module
bad wiring
blown fuses
fried computer
etc etc etc
May 03, 2015 | Cars & Trucks
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
I have a Maytag Neptune washer model MAH5500BWW which we continue to have several problems with. Yesterday our laundry room flooded due to the failure of the incoming water valve being stuck open so the...
im going to try and help if the burnt out part is the motor control and motor ,,you may can get the parts for free,,they had a recall on some of theses models,,go directly to maytag recall.com /whirlpool recall .com...or service matters.com.....heres the number to there recall department 1 800 462 9267...the motor and motor control comes in a kit...good luck
Sep 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
The two wires going to the coil touched and shorted out now theres no spark i replaced coil still no spark 2001 jeep tj 4 cylinder
The driver in the computer may have fried. This means PCM (powertrain control module)replacment. First check #26 20A fuse and the automatic shutdown relay in the power distribution center.
Feb 01, 2010 | 2001 Jeep Wrangler
Leaf blower won't start. I think it's the module
If you haven't done it already, install a new plug. It's possible you're being fooled by a faulty/fouled plug. A fouled plug may not spark visibly - like if there is dirt down in the recesses of plug around the electrode. It would be a good idea to check it with a new plug before spending $80 bucks for a new ignition module.
Aug 10, 2009 | Troy-Bilt Garden
All four burners don't spark no clicking from start could it be a fuse
The surface igniters are controlled by a single spark module. If your model number is correct the module lists for about $18 at appliancepartspros.com. Just type in your model number and look for item 11 (part number AP4098758) under the "Gas Controls" heading. If the model number is not correct, and you still need assistance, please post back and let me know. I hope this helps you.
Jun 25, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
Engine will not start
The 3.8 engine has an electronic control module under the coil pack that commonly fails.
The harness connecting to that unit is also often the culprit of many ignition problems ... its wiring harness fills with water or other corrosives and rots away. So be nice when removing it from the coil/ignition module... There are numbers visible w/o removing it you will need when searching for one to replace it... 1668994 or something like that... you may want to check prices for a used ignition module/coil pack at car-part.com or mypartshop.com... and try a used one to start...
Nov 16, 2008 | 1991 Buick Park Avenue
Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Jun 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
