Question about Homelite Garden
I have a c-51 homelite how many hp is it,and can i mount this engine at a 45 degree angle on a go cart,will it still run
  • Homelite Master
  • 9,742 Answers
  • Type the CC rating into a calculator.
  • Divide the CC number by 15 and press enter. The rule for a CC to HP conversion is there is 1 HP for every 15 CC in an engine.
  • Since it's a 2 stroke you can mount it in any position.
Posted on Dec 05, 2014
How do I miter with my radial arm saw (RA-2500). I can't tell from the manual.
the slide can be angled by the degree plate where the timber sits
the blade can be angled by the degree plate on the arm that mounts the saw
so you can get a 45 degree to the timber length and a 45 degree angle cut to that angle to give you a corner mitre cut
Jul 03, 2017 | Saws
I want to know the torque opel corsa lite 1.4 cylinder head bolts.
stage 1 ... 25 Nm (18 lb ft)
stage 2 ... angle tighten + 90 degrees
stage 3 ... angle tighten + 90 degrees
stage 4 ... angle tighten + 90 degrees
stage 5 ... angle tighten + 45 degrees
Feb 26, 2015 | Opel Corsa Cars & Trucks
Compressor not starting, after it was moved/held at 45 degree on cart while reattaching water line. is there a reset
Good Afternoon Friend,
I understand that the compressor on your Frigidaire refrigerator, model# FRT18IL6DWL, will not start after having the appliance held at a 45 degree angle to reattach the water line. You can reset your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. After restoring power, if the compressor is still not starting, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your refrigerator and determine why the compressor is not coming on. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Electrolux Refrigerators
How do i get my calculator to do the trig problem Tan45=1? It is telling me Tan45=1.61977, and i know that isn't right.
Angles may be measured in three angles:degree, radian and gradians (grads).
tan(45 deg)=1
tan(45 radians)=1.61977
If your problems require angles to be measured in degrees, make sure that the calculator's angle unit is set to degrees.
In RUN screen press [SHIFT][MENU] (SetUp) select the angle line and press function key under the tab Deg (should be F1).
Sep 17, 2013 | Casio FX-9860G Graphic Calculator
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
Homelite ut20024a
cut the very end of the fuel line at a 45 degree angle and try to put it in that way. Once it goes in, cut it flush.
Apr 06, 2012 | Garden
What is the reference angle of 225 degrees and 15'
The answer to this is 45 degrees and 15' i.e. forty five degrees and 15 minutes. Each degree is split into 60 minutes. So that 15' would be 15/60 degrees. that means 225 degrees and 15' is equal to 225.25 degrees. The reference angle is given by = 225.25 - 180 degrees which is equal to 45.25 degrees. This is in fact 45 degrees and 15'.
Please vote for the answer!
Jun 28, 2011 | Computers & Internet
How can I find sin 45degrees 20 minutes using a fx-9750G PLUS calculator?
The problem is not finding the sine of the angle but expressing the angle in Degree Minutes Seconds instead of decimal degrees.
  1. In RUN screen press [SIN] function key
  2. Press [OPTN]
  3. Press [F6] to get to next page of menus.
  4. Press [F5:Angl]
  5. Enter 45 and press [F4: degree ' "]
  6. Enter 20 and press [F4: degree ' "]
  7. If you have seconds to enter, type in value and press [F4:degree ' "]
  8. Press [EXE] to get your result.
This procedure will give you the sine regardless of the angle unit the calculator is configured for.
Sep 30, 2010 | Casio FX-9750GPlus Calculator
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
Garden Logo
94 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
