Question about Kitchen Ranges
Dr is displayed and will clear. oven or cooktop notworking
  • 2,509 Answers
Error code DR can refer to a door lock malfunction. Try resetting by turning off the power to the oven for at least 5 minutes. Power back up, if the error code continues you may have a faulty door latch, or light switch, or in worst case Electronic control unit.
Posted on Dec 05, 2014
Testimonial: "I unplug the stove the dr display is still on. I tried to use the self cleaning oven. It started for a couple seconds,then stopped then the dr display appeared"
The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
Red light on stove surface is lite up red and code pf is on display
"PF" displayed on the control:
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Apr 04, 2014 | Whirlpool Stove / Oven / Range Cooktop -...
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Mar 29, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
Es510
Hello KC - You may try and reset the cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the lock symbol does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control), user interface board or a potential wiring failure. This is not a typicaly do it yourself job; please consult a professional or your manufacturer.
Apr 28, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
How do you unlock a kenmore elite cooktop?
You can do this by:
Check the oven display to see whether the screen says "LOC." When "LOC" is displayed, the oven lock is activated and the door cannot be opened. You need to make sure it is locked so you do not mistakenly lock the door.
  • 2 Press and hold the "Stop" button on the oven control panel until "LOC" disappears from the display. Some oven models have a button marked "Oven Lock," which should be used instead of the "Stop" button.
  • Lock the oven again by pressing and holding the "Stop" or "Oven Lock" button until "LOC" appears in the display
  • Feb 03, 2011 | Kenmore Elite 44173 30 in. Electric...
    Maytag gas oven after self-clean cycle door locked "dr" on displa
    unplug it and let it stand for a few minutes
    let the e- prom clear
    plug it back in, should unlock
    if it does not you need a new sensor
    Sep 27, 2009 | Maytag MGS5770 Gas Kitchen Range
    Code f-7 displays and it is beeping
    Please cut the nonsence and get a brouchure to me, for  JENN-AIR cooktop CCE3401. MY ADDRESS IS 2049 CORLEONE DR., SPARKS, NV 89434. I AM 73 YRS. OLD AND I do not have the time or the patience to chase  Jen-Air around all over the internet! Everytime someone says it is on the internet, then go to Customer Care, then manuals, it is never there, and never that easy! Please. We are in a new house and the performance of the Jen-Air CCE3401W has not been that convincing...
    Apr 12, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Kitchen Ranges Logo
    130 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
