Question about Bosch Dishwashers
I have a bosch semi integrated dishwasher, brand new, which has effortless door closing, worked when first installed with the original laminate panel but the panel was not the right size, since has ha
Nothing, don't want to void warranty
  • Zoe mischewski
    Zoe mischewski Dec 05, 2014
    The machine was straightened when the first panel was removed and since then effortless door closing has not worked. Hoped having the weight of the new panel would sort it but it did not. Any ideas? Hinges feel very stiff now
  • Bosch Master
  • 2,210 Answers
Talk to your supplier or kitchen specialist. If not find your nearest Bosch agent before you void anything. Warranty info and a call number should be in the info that came with it.
Posted on Dec 05, 2014
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Dishwasher door won't close
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door
May 19, 2012 | Bosch Dishwashers
Detergent latch install for Bosch SHU3307UC dishwasher
you need to remove the front panel of the dishwasher. you need to open the door and remove the 6 torx screws on the inside of the door, close the door and lift up and out to remove front panel. you wiil see the detergent assembly there
Jun 25, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
My Bosch Dishwasher doesn't run
double check power to your plug socket ( use bedside lamp)
check fuse in plug
check water supply ( run the water supply directly into pot/bucket)
make sure door closes properly (if built in )
if built in remove and then check!
Feb 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher Door Leaking Steam
Pull the seal that is on the tank 1/2 way out then close the door. This will make sure the door is tight to the seal. This happens sometimes that the seal becomes flattened. I have been using this trick on Bosch dishwashers since this series came out in 1997.
Jan 06, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHV45M03UC dishwasher door leaking
the latching mechinisum is at fault or the door is bent.
Apr 07, 2017 | Dishwashers
Bosch Dishwasher door leaking at bottom, brand new.
Um rough to diagnose without seeing it but there should be a rubber gasket along the bottom of the door. And does the door panel hit the side of the tub when u shut the door? It shouldnt
Nov 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher 2H problem
yes it needs a new control and its pretty easy to replace
Nov 14, 2007 | Dishwashers
Dishwashers Logo
89 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
