Ducane model 92G1UH070BP12-02year and a half old at most this season i have had no heat or lack of heat i have a 3 code on board ( pressure switch open with inducer on )
I have it working walk away then it stops start all over again working on it i have taken the pressure switch out blew air in both directionsafter a few minutes you can hear the valve put it back together glow plug lite up the flame rolls out just washed out drain tube hope that works but any ideas as to what i can do to keep this from happening again and fixing the problem already have a week in this was and its cold here in upstate ny i live 1/4 of a mile from lake Ontario cant afford to replace again as i said year and half old
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
One tip is to inspect very carefully the actual barb connectors that the rubber hoses connect to on the pressure switches. They can become slightly restricted with oxidation or other particulate rendering them ineffective. HOWEVER, your comment that the flame "rolls out" has me concerned. Flame roll out is usually caused by a flu blockage. Many times, if the flue is not covered with a screen, small birds roost in them and hunker back farther and farther for warmth then die from carbon monoxide. If they die at or close to a fitting, they can fall down to the first elbow or 45 and create just enough blockage to effect the pressure switch, but not enough blockage for you to determine without cutting off the flu pipe and physically inspecting.
Another thing that causes flame roll out is a plugged p-trap in the condensing coil drain at the bottom of the blower assembly. It could cause flooding of the condensing coil which cause restriction of air flow through the system, resulting in tripping out on pressure switch.
You may have to cut the flu off in two places depending on how sophiticated you flue is. Usually its not too bad but you'll need pvc glue and primer and a couple pvc couplings to reinstall it. DO NOT operate the furnace with the flu disconnected.
If you find this as the cause, you may want to install a screen over the flu opening but use 1/4" mesh as too fine of screen (screen door) will create too much restriction and also effect the sensitive pressure switches.
Posted on Dec 06, 2014
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Posted on Oct 21, 2008
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
Posted on Dec 11, 2009
SOURCE: My furnace stopped working.
Replace pressure switch. If you blow any air into the pressure switch it has been damaged,check air ports for debris by looking never ,never blow on air switch they work on a very small pressure or vaccum,where your breath is to much pressure and also loaded with unwanted humidity.
boilerman56
Posted on Mar 04, 2011
kingbrizzle
  • 407 Answers
SOURCE: Good morninng, My Goodman furnace inducer
Replacing the board, flame sensor, and pressure switch, and cleaning out the induction motor was definitely a good start. Other things to check would be a blocked or restricted flue pipe, I have ran into a few bird nest before!, and you also want to check or replace the hose that runs from the inducer to the pressure switch if you haven't already. To be honest, most of the time I clear out the nipple on the inducer where the hose goes with a small piece of wire and it works. The last thing I would suggest is making sure the new pressure switch is rated for what you need. Alot of the revisions on furnaces actually call for less than the original pressure just for this problem. Hope this helps and good luck!
Posted on Jul 03, 2011
Brand New Ducane Furnace with Multiple Error Codes
Check your drain line. It appears that water is not draining and backing up into the furnace. Is there a drain trap? If not or if there is no vent on the drain line there can be a vacuum created when the furnace is running and it actually pulls water back into the furnace and when the inducer shuts off it releases the vacuum allowing the water to drain.
Dec 17, 2012 | Honeywell Furnace Air Pressure Switch...
Ducane furnace
Pressure switch is bocked inside try a small drill bit to clean down the connection tubes and blow it out after , check hoses are not blocked or split ,
Feb 12, 2012 | Ducane Grilling
I have a Big Maxx heater that about 4 months old,and it started to act up, when I checked the circuit board I have three flashes. I removed and checked the pressure switch and that checks out fine, I get...
You may very well be right because if the induced draft motor won't come on then the heatin cycle stops there. It makes me wonder about the board because of it doing the same thing even if it's not calling for heat. Thanks.
May 13, 2011 | Mr. Heater Natural Gas Garage Heater -...
Ducane model number 30400040 just received set of (3) stainless tubes to replace the old ones whats the easy way to install
goto ducane web site http://www.ducane.com/manuals/
and download manual. They have Meridian and Stainless models in 3 & 5 burner for LP & NG. Follow 1 year cleaning instructions. Pictures and instructions.
Apr 05, 2010 | Ducane 30400040 Stainless Steel Grill
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
  • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
  • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Ducane high efficiency propane furnace, pressure switch problem
A short cycle heat cycle indicat a pressure switch replacement was needed. This did not fix the problem. the problem was in PCV line since the end was filled with slugs and cause the line to backup with water. When this happen the system would stop asking for gas. the water would leak out and it would restart. The problem was fixed by cleaning value at end of PCV. This released the water, two quart of water, that was back up causing problem. Curious if a filter change indicator was providing a clue that was missed?
Jan 28, 2009 | Ducane 436 inch 2 - 2 burner Grill
Janitrol/Goodman GMP075-3 Draft Inducer Fan Won't come on
most forced draft fans are powered by 120 volts . close to the fan is usually a plug that unsnaps. create a call for heat after turning off to clear safetys and see if your getting 120 to fan on initial call for heat. if you are then fan draft motor is bad, usually sold as an entire assembly replace exact as it came out. sequence of operation is..... stat calls for heat via common and white wire to furnace , 24 volts. ......board sences call and sends 120 volts to forced draft ........ motor runs and creates pressure on proofing switch,....... switch closes 24 to board and tells it draft fan is on......... board then energizes ignitor,....... after ignitior glows gas valve is opened and burner lights ........ either ignitor or seperate sensor rod tells board the burner lit........ and a few minutes later the fan comes on and hot air is blown out. if a step is missed or doesn't proof the furnace either trys up to three times to light or locks out. turning off power usually resets safetys and it will resume attempts to lite normally.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
137 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
